New member Username: DenkeesPost Number: 1 Registered: Oct-08 | I have bought a Bose lifestyle20 powered woofer LSM20CU102515 to use it as a woofer in a non Bose system. I don't have the cubes. I found the pin-out configuration of the 5-pin Din connector so i can connect it. Are the cubes also powered speakers or is there an amp in the woofers for the cubes ? And does anyone know how to open the unit ? |
Platinum Member Username: NuckPost Number: 10930 Registered: Dec-04 | https://www.ecoustics.com/electronics/forum/home-audio/125990.html |
New member Username: Scarab28xltGermany Post Number: 2 Registered: Dec-08 | Hello kees van loon, can you help me im looking for the pin-out configuration of the 5-pin Din connector for my sub to connect the sub to a av-receiver. Thanks for your help. |
New member Username: DenkeesPost Number: 2 Registered: Oct-08 | 1= +12 volt don't need it 2= R- and L- 3= L+ 5= R+ kees |
New member Username: Scarab28xltGermany Post Number: 3 Registered: Dec-08 | Thank you for your fast help. pin1 +12V is it for switch on the sub ?? Have you a picture, where i can see what are pin1 on the connector. |
New member Username: Rishan1Post Number: 3 Registered: Aug-09 | I have a Lifestyl 5 Series III and I need to connect to my Audio Receiver how do i do that? with 5pin DIN connection |
