New member Username: PorchmonkeyPost Number: 1 Registered: Feb-09 | i need a new amp for my alpine type R bridged to 1 ohm. i was looking at a hifonics bki1206 mono 2400w class d amp 1200w rms but was wondering if the sub could handle that much power. any input would be nice. thanks |
Gold Member Username: 04redmach1Www.rdaudio.net, GA USA Post Number: 2518 Registered: Mar-06 | What kind of budget are you workin with? I want to make sure, you have 2 dual 4's right. Feel free to email me if you would like. Kevin se_rdaudio@yahoo.com |
New member Username: Craudi0Post Number: 5 Registered: Mar-09 | well ive heard that the hifonics 1200 really only puts out about 900. and i think the type r may be able to handle a lil more than 500, but not much. so that would definately be enough power |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2408 Registered: May-07 | Budget? Off top of my head... Orion/Directed/DEI D1200 if you are just using 1 sub (Dual 2 ohm coils). AQ1200D or RD1000.1 if you have 2 subs (Dual 4 ohm coils). |
Silver Member Username: Dsmith07NC Http://com4.... Post Number: 902 Registered: Jun-06 | if you have one this would be a nice amplifier for it http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=475 if you have two you could look for its big brother the x1200.1, full power from 1-4 ohms |
