New member Username: GongdaPost Number: 1 Registered: Mar-09 | I can not load any file to my VS X-treme. Help Please...........I was even trying to load the factory file, but failed again. What should I do? Thanks. |
Gold Member Username: GregrafPost Number: 2355 Registered: Dec-07 | Did you unzip the file |
New member Username: Peeps365Post Number: 3 Registered: Feb-09 | what is the problem r u having. specify then i can help but if using a serial cable make sure you are using a loader for the file |
Silver Member Username: MrgregCanada Post Number: 334 Registered: Dec-07 | brad, If you know another way to load a file without a loader(VS Xtreme)please let me in on your secret. |
Gold Member Username: DimwittPost Number: 1160 Registered: Aug-06 | http://embeddedwidgets.netagy.com/viewsatextreme.cfm |
New member Username: Peeps365Post Number: 4 Registered: Feb-09 | make sure u are using that is for the xtreme file should read 0903005-x for example make sure it is the view sat x file |
Gold Member Username: PlymouthCanada Post Number: 8053 Registered: Jan-08 | The answer from Gregraf is right. So this guy not reply with the result. |
