Username: Vincent_law Ca
Post Number: 11 Registered: Apr-08
Friday, March 06, 2009 - 02:09 GMT How many watts do you think it can take on a 2003 cadillac ? I run 1600 easy...but before the up grade ... i mean stock ... i could not go over 2200 before cliping on my amp. any thoghts would be helpful.
Username: Nd4spd18 Philadelphia,
PA
Post Number: 10061 Registered: Jul-06
Friday, March 06, 2009 - 02:31 GMT A stock alt will not support more than 1000w or so, your estimate is a little off there. A 300 amp alternator can supprt quite a big demand with a good battery to go with it. More than 2200w.
Post Number: 12 Registered: Apr-08
Friday, March 06, 2009 - 03:46 GMT sorry i am off and on when i can talk. the reading i get off my car is 14.8 i have a optima red i know you dont care for them but thats what i got. do you think i can run another 15?
PA
Post Number: 10063 Registered: Jul-06
Friday, March 06, 2009 - 09:05 GMT Voltage is not what really matters here as long as its good. With a 300 amp alt you can run quite a lot of power.
Username: Tatonka -[Team Audible
Insanity]-
Post Number: 2754 Registered: Mar-07
Friday, March 06, 2009 - 14:24 GMT quote: A stock alt will not support more than 1000w or so, your estimate is a little off there.
Mine supports 4k.
Diamond Member
Username: Wingmanalive Www.stainles...
.ecrater.com
Post Number: 20017 Registered: Jun-06
Friday, March 06, 2009 - 22:56 GMT Vid with a half naked chick or it doesn't exist. Seriously, you like living on the wild side lol?
Username: Hittin1 TEAM REVOLUTIONLake Charles...
Post Number: 2687 Registered: May-07
Saturday, March 07, 2009 - 00:15 GMT quote: Mine supports 4k.
prove it. get it to Lafeyette tomorrow. seriously, what's up with your bags? why can't you bring it?
PA
Post Number: 10066 Registered: Jul-06
Friday, March 13, 2009 - 03:30 GMT Vid with a DMM showing voltage holding at 13.5+ with a 4kw draw would be more like it.... ain't gonna happen.
