Dummy needs help with box choice
Username: Erslo
Post Number: 8
I've been using a Pansat sm250, and a Viewsat Ultra.
It seems the Nfusion is the way to go, but I don't know much about this to make an educated guess. I don't know, given the possibility of DN going to Nagra3, if buying any box today would not be a waste of money.
I sure would appreciate some opinions. Thanks in advance for any help.
Username: Nydas
Post Number: 14538
As of now, the advantages Nfusion has over others are:
1. Less likelyhood of ECM affecting the receiver.
2. BEV Nagra 3 channels are visible.
How long these advantages last is anybody's guess.
Username: Dimwitt
Post Number: 1144
Dimwitt need help too,
Need more fta stb's that will open N1 channels @ 95w.
The newer pansat models don't work, older models with older bins work.
cw600s with current bins work.
Can anyone test those channels with vs, c00lsat or any other stb.
keys are in this link , rtn 0801,0901
https://www.ecoustics.com/electronics/forum/home-video/Softcam_200908_hex-521428.unk
Username: Plymouth
Post Number: 7938
Tooter
I confirm, all RTN, OTB 1-2. RDTHN and HRTV wide open on Viewsat Ultra with these keys.
But not easy to create the provider for it.
After many try I know how do it now.
Username: Dimwitt
Post Number: 1145
Thank you !
Username: Plymouth
Post Number: 7939
Tooter
You are Welcome!
Do you know if, we can do it on other satellites?
"""The newer pansat models don't work, older models with older bins work."""
I'm not sure that is the bin, but the possibility of created a new provider(C9 01 00) and the keys, on my viewsat, the button save is not listed in menu, I found while testing different button on remote.
Username: Plymouth
Post Number: 7996
Tooter
Username: Dimwitt
Post Number: 1148
Plymouth , I only know of the channels at 95w.
Username: Plymouth
Post Number: 7998
OK Thanks Tooter
