Pansad 2700a
Username: Boling
Post Number: 42
Can someone please guide me how to set this up on my pansat 2700a. I have not been getting picture since last week. I only get scrambled channel.
"Make sure Dishnet autoroll is Off and Keycode autoroll is On"
How do I navigate to do the procedures from above?
Thanks in advance.
Username: Dimwitt
Post Number: 1147
While on a channel - enter 8282 on remote- select autoroll, you should also select set default key , exit out of menu and wait on channel 200 for the keys to roll.
you can also enter the active key from the same menu page -nag2
