hey, trying to install my new DN and using a viewsat ultra.
On the install screen got 110 port1 and 119 port 2. then did a scan of both sats.
Now for some reason i have double even triple ch's, tried a few times and kept getting the same thing. So i went to my LNB and say that it says LNB A ON, and LNB B OFF.......is this my problem??
cause then i tried a different LNB that had 4 ports, did the same thing as before and everything works fine.
so is there something i have to turn on or off to se that other LNB or is that LNB garbage??
Jon do a factory default then rescan both satellites with good setting, autoscan one by one with this antenna setting:
LNB Type: OCS-DP if you use a Dn dish and standard if you use a generic dish. LNB freq: 11250 for both Tp Freq: 12224 for both Diseq: select the port which you had put LNB on switch.
