Question for Plymouth
Username: Rafiq128
Post Number: 157
Hi plymouth can you please tell me how to get 7 days EPG on viewsat ultra. thanks
Username: Plymouth
Post Number: 7966
Bhatti
Menu,Users setting, EPG Setting, on EPG TP with left arrow select 12486 on E:.
now on Receiver Guide press OK and wait until it finish.
Be sure 7 days is selected.
Now you must have the EPG for 7 days.
Username: Rafiq128
Post Number: 158
Thanks Plymouth i will try it. Thanks again
Username: Plymouth
Post Number: 7969
Bhatti
You are Welcome
Username: Rafiq128
Post Number: 160
I just tried it but got only 3 days epg and i selected 7 days. any other idea ? E was 12486 and n was default is it ok like that or should i change the setting.
Username: Plymouth
Post Number: 7970
Bhatti
E: is Echo and N: is Nimiq, you don't need to put Tp on N:.
If you don't have enough memory in you receiver because to much channels you will not totally populated the EPG.
You can try 12443 also.
Username: Rafiq128
Post Number: 161
ok i will try 12443 Thanks again
