Bronze Member Username: Sandy12421Post Number: 71 Registered: Jul-06 | i wanna buy nfsion but i wanna know i want a have to have internet and i have to connect with nfusion and can i see nimiq 1 and 2 |
Gold Member Username: GregrafPost Number: 2332 Registered: Dec-07 | These are the channels you can get with Bev but you need to have it hooked up to the internet for it to work. https://www.ecoustics.com/electronics/forum/home-video/552839.html |
Bronze Member Username: Sandy12421Post Number: 72 Registered: Jul-06 | which one is best nova or solaris |
Gold Member Username: GregrafPost Number: 2333 Registered: Dec-07 | Either one is good. Just make sure you dont buy a clone. The nova isnt being made anymore but the support will still be there. Ive got a Nova and am quite happy with it. |
Gold Member Username: GregrafPost Number: 2334 Registered: Dec-07 | This is a helpful place but you will have to join. [link removed] |
Bronze Member Username: Sandy12421Post Number: 73 Registered: Jul-06 | i like to buy solaris thats fine we dint have any problem to find a file |
Gold Member Username: GregrafPost Number: 2336 Registered: Dec-07 | Its a newer model and cheaper so good for you. My viewsat extreme is being used for a doorstop now |
Bronze Member Username: Sandy12421Post Number: 74 Registered: Jul-06 | pls can i have new boot file |
Gold Member Username: GregrafPost Number: 2339 Registered: Dec-07 | Why do you need that if you dont have a reciever yet? |
