Username: Pj94z Post Number: 67 Registered: Nov-07
Saturday, February 28, 2009 - 18:56 GMT I have a viewsat and sonicview. I see that there have not been any new fixes come out since 1/09. It is now almost 3/09 and my units are freezing or no signal (sonicview). anyone know where I can find the updated fixes , if available?
Username: Viruscauser Leesburg,
Georgia
Post Number: 1004 Registered: Mar-07
Saturday, February 28, 2009 - 19:02 GMT Best place to get them without becoming a member: http://currentbins.com/ftafiles/
Username: Plymouth Canada
Post Number: 7843 Registered: Jan-08
Saturday, February 28, 2009 - 19:26 GMT pjx simply reload the latest bin file from good site that Abby list. Sonicview never goes down since 1 months. You can try a hard reboot first.
Username: Lomna Post Number: 512 Registered: Dec-07
Saturday, February 28, 2009 - 21:09 GMT Yes! plymouth, sonicview rocks.
Username: Kirankumar NO Bashing
Post Number: 3113 Registered: Oct-07
Saturday, February 28, 2009 - 21:13 GMT sonic view has no problems check your cables,connections and antenna set up
Post Number: 7848 Registered: Jan-08
Saturday, February 28, 2009 - 21:19 GMT African Sonicview experiment many problem only because never reset, that is why a hard reboot clear the freezing, sound lost, remote problem and slow EPG display.
Username: Txlatino1983 Post Number: 1 Registered: Feb-09
Saturday, February 28, 2009 - 21:28 GMT Hi Guys, Im having the same problem. I reloaded latest bin and rescaned both satellites.. Signal an quality is good but still get scrambled or no signal.. What setting does autoroll option have to be on? I have sonicview elite it was working fine but started going bad wednesday.. Thanks for all your help.
Post Number: 7853 Registered: Jan-08
Saturday, February 28, 2009 - 21:42 GMT Miquel Try to put the autoroll off and put the keys manualy: Dish Network (0101) [Last update: Fri. Feb 27, 8:07 PM CST] 86: EE 81 EF BB D8 9F 8C 00 EE 06 35 E2 1C 1B 92 58 96: FE 4C 22 B6 AE F8 17 F6 68 69 FD 64 36 87 9E A8 New Dish Network New Provider ID (0106) [Last update: Thu. Aug 28, 4:14 PM CDT] 86: C9 DC DB 84 5A B8 2C DF 7F 32 8D E5 21 5C 45 4E 96: 4E B1 A8 DA 2D 92 90 D9 E6 3C 5E CE E4 FE E3 86 New
Username: Txlatino1983 Post Number: 2 Registered: Feb-09
Saturday, February 28, 2009 - 21:55 GMT Are these keys for the Sonicview elite 360?
Post Number: 7854 Registered: Jan-08
Saturday, February 28, 2009 - 22:14 GMT Miquel those keys work for all receivers.
Username: Txlatino1983 Post Number: 4 Registered: Feb-09
Sunday, March 01, 2009 - 03:08 GMT do i have to restart once i put in the key? or upload the latest bin again?
Post Number: 7871 Registered: Jan-08
Sunday, March 01, 2009 - 03:17 GMT Miquel First thing to do is reload the latest bin when your receiver doesn't work. For now I have no comments that the Sonicview need to enter the keys manualy, but if it doesn't work you can put the autoroll off and enter those keys and post the result.
Username: Txlatino1983 Post Number: 5 Registered: Feb-09
Sunday, March 01, 2009 - 03:19 GMT i just entered the keys you gave me. it let me enter half of each code.. i saved and still get the "No service or scrambled"
Username: Txlatino1983 Post Number: 6 Registered: Feb-09
Sunday, March 01, 2009 - 03:24 GMT I loaded the latest bin once again.. Then turned the autoroll back to On.. I waited for a couple of minutes and the signal came back on!!! Thanks lot Plymouth!!!! Great to see that people out there are still willing to assist.. Have a good one buddy!
Post Number: 7872 Registered: Jan-08
Sunday, March 01, 2009 - 03:28 GMT Do a factory default, load the factory bin from http://currentbins.com/ftafiles/ then do a autoscan on each satellites and it will work now.
Username: Pj94z Post Number: 68 Registered: Nov-07
Sunday, March 01, 2009 - 16:59 GMT thanks guys. my units work, except the VIEWSAT VS PRO is still freezing every 3 mins...even with the latest fix from 2/27 No matter which channel I watch, the picture gets stuck for about 3-4 mins, then resumes again....but very hard to watch anything that way The sonicview works like a champ.
