ok i have 3 kickers cvr's 4 ohm in a sealed box and was running them off a kicker zx700.5 which did abou 930 rms for just the subs. but i found a jl 1000/1 barley used for 300 so will i have any problems running that with these subs? over powering maby?
If they are dvc 4's, you will see a final load of 2.66 ohms. So each sub will see ~333 watts. Not over powered. It will be better then the kicker in this app.
