New member Username: LalondtmEast Lansing, Michigan Post Number: 10 Registered: Feb-09 | Im looking to replace the stock door/rear deck speakers in my 2001 impala. the door speakers are 6-3/4" and the rear decks are 6x9. I want them to keep up with my 2 subs (kicker cvr12 400w each 4ohm). there is already an amp installed (im guessing factory??) in the truck for the stock speakers. I'd like good SQ, with some L, but i dont want to spend TOO much. any suggestions??? |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9838 Registered: Jul-06 | Exactly how much can you spend. If you want really good sound and loud an aftermarket amp and a set of high end speakers is in order. If you just need something to sound better than stock, thats not hard at all. |
Bronze Member Username: LalondtmEast Lansing, Michigan Post Number: 11 Registered: Feb-09 | well i plan on replacing the speakers first just to get some better quality, and then adding an amp to juice them a little later so i can spread out the cost |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9853 Registered: Jul-06 | How much..... speakers can be $100 for budget models to $500 and high for top end ones. |
Bronze Member Username: LalondtmEast Lansing, Michigan Post Number: 13 Registered: Feb-09 | I'm looking to spend maybe around $200- $300 total for all 4 speakers (2 door and 2 rear deck) I was looking at maybe something along the Polk db series?? After I replace them, I'll look into replacing the factory amp as well. |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9861 Registered: Jul-06 | You'd be best off putting the entire budget on front components.... exige can get you a good deal on something, probably can get a CDT HD set. But I'd recommend saving a bit more for an ES set. Rear speakers don't do anything good... more on that: http://www.glasswolf.net/papers/rearfill.html Those polks are not very good, and $150 a set won't get you anything great. |
Bronze Member Username: LalondtmEast Lansing, Michigan Post Number: 14 Registered: Feb-09 | thanks for the link, very helpful ![]() |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9900 Registered: Jul-06 | woofersetc.com sells then but prices are rediculous. Exige audio on here sells them for much less. cdtaudio.com is the comapnys website |
Gold Member Username: Drant19DUB-C, TX Post Number: 1430 Registered: Aug-07 | talk to Mike(Exige Audio) very helpful and a great guy to do business with. i wish i had the money so i could do business with him again haha |
