im looking at buying a single 15" Kicker SoloBaric L7 1000 watt RMS (2 ohm, i think) to go in a 96 Honda Accord 4dr and was curious if this would be a good amp to pair it with?
MA AUDIO M1900XE: * 1000 watt mono-block high powered amp * competition series * 1000 watts RMS @ 2 ohms * 2 ohm stable * Adjustable Low Pass Crossover Network * Thermal, Short and Overload protection * MOSFET Power Supplied * built in sub sonic filter * High/Low level inputs * THD: 0.05% * Preamp Outputs * Channel Separation * Bass Boost 0 - 18 dB * Dimensions 13" L x 10" W x 2" H
are you stuck on the kicker? there's much better out there than that. read around on the site you'll find out. if you are stuck on it, that amp prolly wont work cause im sure ur sub is a dual 2ohm. you'll need and amp thats 1ohm stable. ask for help in the subwoofer section, theres alot more traffic there
if you are going to go kicker, get some cvx's. they sound way better than the squares. They are pretty affordable too. just a thought. If it were me, rd alpha all the way.
