New member Username: Notw000Post Number: 7 Registered: Feb-09 | Sorry for the excessive opinion threads... but here is one more. The amp in question is the "Power Acoustik BAMF-5500/1D AMP". $269.99 Here is the ebay link, http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=110344182308&Category=18795 . Here are the specs: # SPECIFICATIONS * Amplifier Class : Class D * Number of Channels : 1-Channel * Maximum Power : 5500 Watts * RMS Power Output @ 4 Ohms : 1700 Watts x 1 Channel * RMS Power Output @ 2 Ohms : 2500 Watts x 1 Channel * RMS Power Output @ 1 Ohms : 3200 Watts x 1 Channel * Bridged Power : N/A * THD (Total Harmonic Distortion) : 0.5% * Signal-to-Noise Ratio (dB) : 100dB * Frequency Response (Hz) : 15Hz~150hz * Built-in Crossover : N/A * Subsonic Crossover Frequency : 20Hz-50hz * Low-Pass Crossover Frequency : 40Hz~200Hz * Bass Boost : 0dB~18dB * Bass Remote : Yes * Fan Cooled : N/A * Fuse Rating : N/A * Dimensions (Width x Height x Depth) Inches : 17.1" x 8.26" x 2.16" * Approximate Weight : 12.8 LBS ALSO CHECK OUT THIS AWESOME DEAL ON A PLANET AUDIO AMPLIFIER!! Wish i could buy it!!-----> http://cgi.ebay.com/PLANET-AUDIO-3000-WATT-CLASS-D-MONOBLOCK-AMPLIFIER_W0QQitemZ 200311093755QQcmdZViewItemQQptZCar_Amplifiers?hash=item200311093755&_trksid=p328 6.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|29 4%3A50,http://cgi.ebay.com/PLANET-AUDIO-3000-WATT-CLASS-D-MONOBLOCK-AMPLIFIER_W0 QQitemZ200311093755QQcmdZViewItemQQptZCar_Amplifiers?hash=item200311093755&_trks id=p3286.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293 %3A1|294%3A50,http://cgi.ebay.com/PLANET-AUDIO-3000-WATT-CLASS-D-MONOBLOCK-AMPLI FIER_W0QQitemZ200311093755QQcmdZViewItemQQptZCar_Amplifiers?hash=item20031109375 5&_trksid=p3286.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301% 3A1|293%3A1|294%3A50 |
New member Username: Notw000Post Number: 8 Registered: Feb-09 | bump. http:// cgi.ebay.com/PLANET-AUDIO-3000-WATT-CLASS-D-MONOBLOCK-AMPLI%20FIER_W0QQitemZ2003 11093755QQcmdZViewItemQQptZCar_Amplifiers?hash=item20031109375%205&_trksid=p3286 .c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301%%203A1|293%3A1| 294%3A50 |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9929 Registered: Jul-06 | power auoustic amps are not very good quality. |
Gold Member Username: Drant19DUB-C, TX Post Number: 1432 Registered: Aug-07 | not good quality at all..and thats coming from someone who owns one ![]() that amp wont do rated power whats your budget? any electrical upgrades? what subs do you have? vehicle? |
New member Username: Notw000Post Number: 9 Registered: Feb-09 | my budget is around $500-550. i havent done the big3 yet. i have an audioque hdc315D1. nissan frontier crew cab. i am using an alpine mrd-m1000 rated at 1000wrms. it gets pretty loud but i know that the speaker is being under powered if a saz-3000d can push 149db out of it. what do u recommend? besides an aq amp. |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9948 Registered: Jul-06 | Although the sub could take more, 1000w is enough.... SPL is mostly to do with the box, not very much with the amp. |
Gold Member Username: Drant19DUB-C, TX Post Number: 1436 Registered: Aug-07 | what are the specs of the current box the HDC is in? |
New member Username: Notw000Post Number: 10 Registered: Feb-09 | the box is 4.5ftcubed after port and speaker displacement. i tuned the box at 36hz instead of 38 or 40 due to the excessive low frequency tones i listen to. *EDIT*oh and the port is a slot port.*EDIT* |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2397 Registered: May-07 | Is this sub a dual 1 ohm? |
Bronze Member Username: Notw000Post Number: 11 Registered: Feb-09 | yes dual 1's. |
