New member Username: PorchmonkeyPost Number: 2 Registered: Feb-09 | hifonics bxi1206 mono 2400w max. is this a good amp? i am going to be running an alpine type r dual voice coil 12 inch. |
Silver Member Username: Vivi2000Owosso, Mi Post Number: 120 Registered: Aug-07 | It is a good budget amplifier, it will not come close to 1200wrms at 1 ohm though. Mine does about 800-900 before i can hear distortion in the subwoofers. What is your budget for the amp? |
New member Username: PorchmonkeyPost Number: 3 Registered: Feb-09 | well i found a good deal on one for 170$ on ebay. so around 200$ |
Silver Member Username: Vivi2000Owosso, Mi Post Number: 125 Registered: Aug-07 | Thats an ok price. If you can spring $50 more you can get an AQ1200D(AudioQue) which will put out rated power. http://www.audioque.com/aq/AQamps.htm It is $250 shipped straight from manufacturer. |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9968 Registered: Jul-06 | As stated here it is overrated but will do the job if you need a ~900w amp |
New member Username: PorchmonkeyPost Number: 4 Registered: Feb-09 | thanks for the help |
