SP: 1. "how to get bev 82 signal in ca san jose," BEV 82 is now spot-beamed by Nimiq 4. it does not reach California - might reach north California with a large Dish.
2. "any special lnb or dish ,i got 91 ,72 77,but not 82" Also 82 has a lot of HD channels, you need a special receiver and a subscription, except that a few non-HD channels are visible using Nfusion receiver.
SP.. I'm in Sac cali. I have tried 36" but it is not helping. you may try larger than 36" If that helps please let us know. Nalin, I do have a question for you. Do you think bev may change nomiq4's position later Or once provider launch a sat, it stays at the same position for good.
It will probably stay where it is for a while. It has been a major change. However, the beam might change, in which case, you will see even in Southern California. We will see a considerable shifting once DN has completed their N3 implementation.
A dual DISH dish (110 119) should work (82 91)are same spacing or just use single lnb pointed to 82. problem is you need HD decoding &/or signal might not be getting there. Also EVERTHING on BEV has gone N3( NO crack yet as far as I know) You are probabley NOT receiving 91 now. Ergo you will not get 82 either. Same prob I have in Fla. without my legit sub.
