Silver Member Username: MississaugaPost Number: 101 Registered: Apr-06 | HI Sada 1) I have a Viewsat Ultra. If I want to switch to Nfsion do I have to make any changes to my dish set up or simply switch the cable from Ultra to NFsuion. 2) Do you have a link to how the NFsuion box is set up |
Gold Member Username: KirankumarNO Bashing Post Number: 3097 Registered: Oct-07 | hi, i know this question is for Sada,but i know he won't mind if i answer it for him you can use nfusion without making and changes to your dish,just unhook cable from vs and hook it up to nfusion. as far as setting it up is concerned,you can go to any reputable fta site and go to the guides section and you will find very good instructions there.try |
Gold Member Username: GregrafPost Number: 2242 Registered: Dec-07 | this sites good too [link removed] |
Silver Member Username: MississaugaPost Number: 102 Registered: Apr-06 | Thanks guys. Appreciate the help |
Silver Member Username: MississaugaPost Number: 103 Registered: Apr-06 | One more question. Which is the best Nfusion box to buy? I have my internet connection in first floor and the TV is on the ground floor. Is there a wireless connection\router bundled with the box so that I do not have to run an Ethernet cable from the first floor And finally which is a good place to buy in Toronto\Mississauga area Thanks |
Silver Member Username: Pannu16Post Number: 808 Registered: May-06 | dont buy anythin right now.. u r better off waiting 2-3 months and knowing a clear picture!! |
Silver Member Username: LomnaPost Number: 488 Registered: Dec-07 | Yes I agree with Mr Pannu. |
Gold Member Username: KirankumarNO Bashing Post Number: 3098 Registered: Oct-07 | if you ever need to buy any fta stuff in your your area,there is a very reputable store there called transat electronics |
Silver Member Username: Rafiq128Post Number: 151 Registered: Feb-08 | In Mississauga area Angel electronics on 1515 Matheson Blvd East Its near Dixie road and matheson blvd. Phone 905-602-1382 |
Gold Member Username: GregrafPost Number: 2244 Registered: Dec-07 | I love my Nfusion so i say buy it. We live in Canada so we can afford it. You can spend $200 out one night drinking. |
Bronze Member Username: Boss_hogPost Number: 58 Registered: Oct-08 | Transat Electronics http://transatelectronics.com/locations/ Etobicoke, Brampton, London, North York (TBA), Newmarket, Oshawa |
Gold Member Username: Saqeeb9000Post Number: 4519 Registered: Oct-07 | missisauga user i think this will be right time to buy nfusion before price will ber rocking .. they got internationals now for bev and other stb's are waiting. best nfusion is hd model but that is expensive so i won't go for it .. solaris is good basically nova/solaris all same thing. if u are buying from trasat electronics , really good to place buy u won't be buying a clone, ... u don't need to make any changes to dish as african said.. as for ur connection, i guess u mean u have interent router downstairs and u wanna get ur nfusion hooked up upstair in bedroom (in this case if u don't want network cable all over ur house) u need a power line adapter .. zyxel have good one, when u are buying it with ur nfusion buy adapter will that will be cheaper, buy the one with atleast 85 mbps or higher..any network adapter will work.. The way a powerline adapter works is pretty simple. It consists of two parts that each plug into the wall and use your existing power lines in your house to transmit the signals between them. Plug one adapter into an outlet by your router and connect it into the router with an Ethernet cable. Plug the other adapter into an outlet by where you need the Ethernet connection and you are done best luck. |
Silver Member Username: MrgregCanada Post Number: 313 Registered: Dec-07 | Transat does not sell Nfusion anymore so try this one. http://www.thedigitalstore.com/home.php |
Silver Member Username: MississaugaPost Number: 104 Registered: Apr-06 | What do you think of the Kbox sold by Transat Electronics. Is it the same as NFusion. Do you recommend this? |
Gold Member Username: KirankumarNO Bashing Post Number: 3100 Registered: Oct-07 | try this supplier they are reputable as well http://www.worldwidesatellites.com/catalog/ |
Gold Member Username: Saqeeb9000Post Number: 4524 Registered: Oct-07 | } of using iks and standalone, use standalone option during the off peak period and during ecm switch to iks ... ever thing is good.. except.. all nagra 3 channels are down on k1plus,on other hand nfusion is up if u are looking for features pvr, k1plus u might be looking for, if u are looking for reciver as best up time and u wanna see nagra 3 channels then nfusion.. |
