Good 12" sub
Username: Dudeman135
I'm looking to put a 12" sub in a 2009 Pontiac G8 GT. Huge trunk, but don't want to go too big and add a bunch more weight.
I'm looking to spend 250 or under for the sub/sealed enclosure. I'm used to a 10" MTX Blue Thunder sub in a sealed enclosure that I've had for 10+ years with a Profile AP600 300W RMS at 4 Ohms as a reference point. I'll probably get the same or similar Profile AMP. I listen to mostly Heavy Metal-Metallica, Queensryche, Dokken...but occasionally throw in some 80s bass like Ice-T, 2 Live Crew, etc.
Suggestions on a good sub/enclosure would be great. I'd prefer a sub already in a sealed enclosure, but could purchase separately. Thanks
Username: Blazerboy
15 $$D wangi...
Post Number: 636
What are you looking for in your sub? More sound quality (SQ) or pure loudness (SPL)?
Whats your budget for a sub, box, amp, and wires?
I would say probably a balance of both, with a slight edge towards pure loudness (SPL) over sound quality (SQ). I was estimating $250 for the sub/sealed enclosure and the amp that I mentioned is currently around $110. I also need a line output converter which is about $20. So approx $380-400 total.
Username: Mgbcs
Maple Grove, Minnesota
Post Number: 2754
Well if you want the kick drums and all the good stuff that come along with heavy metal you're going to want to lean more towards SQ IMO.
Additionally, I would suggest getting a better amp, unless you are very satisfied with the Profile.
In my price range, do you have any suggestions as far as specific sub/enclosure/amp?
Username: Jtown
Texas
Post Number: 3595
I'll sell you my 12" Revolution Design Alpha v1 for 170 shipped.
1000wrms recommended.
I've never heard it in a sealed enclosure, but it does really well ported at 32hz IMO.
Username: Cozce
St. Louis ILLside, Pronounced: ... U.S.A.
Post Number: 550
I have an Alpha v.2 i'd like to sell, sorry thieves lol
Username: Jtown
Texas
Post Number: 3597
don't be sorry, I posted first :-) you can sell on CA or something.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9825
Sweet car, get some pics up.... and you play good music, double win
My rec for sub would be a RD Sonance or Fi Q.... for an amp, profile is not that good, you can get far better amps.
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2361
How much power are you wanting to run?
How much power? As much as I can buy for about $400 total for amp/12" sub/sealed enclosure. Most bang for the buck. But I want it to sound good, not just loud booming, not into turning heads just want it to sound good and want to be able to feel it. And thanks for the offers of used subs, but I'd prefer to buy new even though I know worked in subs sound better.
Nd4spd18 wanted some pics, here's one of the car and trunk where I'll be putting the sub. The battery is actually in that little compartment on the left in the trunk.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9836
Well $400 does not get you a lot (of good stuff) in the car audio world but we can work with it.
I would talk to kevin holden, hes an RD dealer, and get a good deal on one of RDs SQ based subs. Then maybe a small 500w or so kicker or phoenix gold amp. After choosing that stuff you can prob find a prefab sealed box to save on cost there. (careful though it has to be a good one)
That battery in the back design will be very handy for your wiring, and big 3 upgrade ain't needed for the amount of power you will have.
Ok, would this setup rock?
JL Audio 12W3v3-4
Sonic Sub Box: 1H12-1.0
Phoenix Gold Ryval V8001
Good combo? The Amp has speaker level inputs, can I splice into existing speaker wires and be good to go or is it still better to use a line output converter to feed it with RCA cables? If so, what is a decent one? The one I have in the other vehicle is an AudioLink PowerLink II and apparently it's discontinued, which sucks because that thing rocks, had a high pitched whine in several vehicles and that completely eliminated it. Love that thing. But I'm sure there are other decent alternatives if I need one?
I've seen some reviews of amps in general talking about Amps powering off to prevent from overheating. I've never experienced before, are certain Amps prone to overheating or is it just a matter of having all the settings all the way up and turning your head unit to the max also?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9876
JL stuff is very overpriced... how much are you paying for that? You could almost surely get something better for the same price from a brand like RD.
Here's price, haven't searched around yet for lower price and am not dead set on that, just thought it sounded like a good combo:
JL Audio 12W3v3-4 $169.99
Sonic Sub Box: 1H12-1.0 $24.99
Phoenix Gold Ryval V8001 $149.99
Username: Nd4spd18
Philadelphia, PA
Post Number: 9882
Thats actually not bad.... JL is good stuff.
Only problem is that box.... at that price you can be almost sure its going to be crap. Box needs to be made from 3/4 MDF at least for good performance and any kind of longevity.
Post Number: 7
It looks like a pretty solid box surprisingly and it does happen to be 3/4 MDF. Out of stock currently, so hoping they restock soon.
http://www.sonicelectronix.com/item_7590_Sonic+Sub+Box-+1H12-1.0.html?utm_source =froogle&utm_medium=organic&utm_campaign=froogle
