Help please??
Username: Semperfi
Post Number: 76
ok, so right now im giving my system to my wife (aq1200 idmax 10) she is going to be driving an 02 accord coup.
i plan on gettin a new car (93-99 eclipse) and i wanna get 2 10's idc about trunk space, i prefer SQ. lookin to spend around 3-500 a sub plus amp and deck. all in all this car wont have anything good in it most likely so it will be a total redo new or used as long as the person is trust worty...
i was lookin at AQ and idmax again, but i'd like some variaty from what i have now you know?
Username: Jtown
Texas
Post Number: 3565
hmmm...I've been thinking about selling my system and getting a 15", maybe two and a big boy amp.
I have 210" SS rl-is, off of an RD 1000.1D, sounds awesome, but I think I want higher intensity at the same note (33hz)...
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2495
Sean bought 2 PG 10's for under $100 IIRC. They should sound good and would require very little power.
Username: Hittin1
Post Number: 2496
If you are wanting a better quality sub, check into the
AP REVO
RE SX
Thieves lil SS RL-i setup
Infinity Perfect Kappa's, ect...
Username: Semperfi
Post Number: 77
what about RE XXX do they have good SQ? it doesn't have to be 2 10's it could be one 12" or 1 15" any other suggestions?
Username: Insearchofbass
Post Number: 11323
"Sean bought 2 PG 10's for under $100 IIRC. They should sound good and would require very little power."
90 a pair shipped dual 4ohm
They take 350 rms a piece not 500.
http://www.dealercostcaraudio.com/search.aspx?manufacturer=25&log=false&high=50. 00&category=337
Username: Semperfi
Post Number: 78
anyone think the XXX is a good idea?
Post Number: 11324
the 04 05 version yes
Username: Semperfi
Post Number: 79
not the new ones? why those ones?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9802
The new ones are insanely expensive thats why people don't recommend them.
Post Number: 11325
The 04 05 also sound better from what ive read others say.
Username: Semperfi
Post Number: 80
because of the age and hours on the motors on the 04-05 and you don't know the condition of the way the subs were treated wouldn't it be more risky to buy that old of a model?
Username: Rovin
1 15 = 149.5 DBs ...Trinidad & T...
Post Number: 14741
recently head a 1 10 IDQ ported tuned 34hz which is too high for me but it sounded pretty good
...can also recommend 2 10s RE SE sealed since thats what im running right now ...
Username: Nd4spd18
Philadelphia, PA
Post Number: 9808
Motors will last forever... it's soft parts that "wear"
Fi can recone them....
Username: Semperfi
Post Number: 81
ok, if money wasn't an issue what would be one of the best 10-12 subs
Username: Semperfi
Post Number: 82
SQ Subs**
Username: Van_man
Boston South, MA
Post Number: 4626
you know its coming...wait for it...wait for it.....
JL W6 10" or 12"
I would run the 10" off ~600wrms and the 12" off ~1000 rms.
Prices have come down quite a bit on used ones.
for an amp...you need someting that does it at 2 ohms, as the w6's are dvc4's
mybe an aq1200. idk what the 2 ohm rating is off hand.
Username: Snowball123
West Allis, WI
Post Number: 2227
870 i think.
Username: Semperfi
Post Number: 83
if i were to do the JL then i'd get 2 10"W6v2's...
