Fi. vs. Re
Username: Poundhardheh
Palmerston, Ontario Canada
Post Number: 31
Hey I'm looking at a new system for my 96 Cutlass. I'm looking at 1 15" Fi Btl, or 2 12" Fi Btl or 1 Re XXX. I need opinions on what would be the loudest and best SQ setup? Also Cheapest considering what I need to power the subs, and also I want a setup where I dont need to do to much to the electrical system. I am fading toward the Fi's.
Post Number: 32
I really need an opinion on which subs to buy and what to power them with and what electrical uprades I would have to do! Thank you
Username: Nd4spd18
Philadelphia, PA
Post Number: 9849
Fi Q is what you need. BTLs are not for SQ, those are SPL subs. RE XXX is one of the best SQ subs ever but the good ones are no longer produced.
Username: Tejcurrent
Post Number: 1720
BTLs will need the a lot of electrical upgrades.
I would go with 2 qs from the way you say you want SQ. Others can suggest some amps. What's your budget look like for everything- including electrical upgrades?
Username: Caesar1212
Brandon, Fl
Post Number: 20
isnt it true that re is a brother company of fi or vice versa?
if so then why is re so much more expensive?
Post Number: 33
Hey, If I got 2 Fi Q's will they pound pretty hard, Because I am looking for something that will pound crazy! And If I did get the two what would I need to power them both with?
And yes they are brother companies.
Post Number: 1724
Re was built originally by a guy named Scott and a partner
They sold the company to us amps who then jacked the prices up.
Scott then started Fi. He keeps fi products out of stores and cuts overhead, while re is now sort of a big brand.
Post Number: 34
Well Im looking either, 2 12" Fi Q's or 1 12" Re XXX. I want a mix of great sound quality and SPL, which setup you suggest?
Post Number: 35
I was just looking into the subs, and heard alot about tinsel slap and spider problems. And also people said more to go towards the BL cause it still has great Quality but pounds alot harder than the Q's but I have no idea. I dont know these subs very well.
Also any other makes of subs that pound hard and still have good SQ. Ill spend around $1200 on subs, so I'm looking for something big!
Post Number: 36
Also I seen Soundstream XXX 15" 2 for $1000. I seen there 8500 watt. So that means big amps and big electrical upgrades right?
Username: Terra
Post Number: 25
The C-D Omega was designed to be basically a BTL that sounds good. Reviews say it achieved that.
www.cascade-designs.com
Post Number: 1725
That's peak not rms ratings.
Two bls are sounding a lot more like what you're looking for.
How much are you willing to spend on amps and charging upgrades?
Even 2000 watts should really have an upgraded alternator and extra battery imo.
Post Number: 37
Well right now I can get a great deal on Soundstream XXX 6500 amp and 15" Soundstream XXX sub for $1200 but I have no experience in this make.
My Budget is like $3000 for everything
Username: Nd4spd18
Philadelphia, PA
Post Number: 9855
" heard alot about tinsel slap and spider problems. "
That was true when Fi first started out. The subs have been redesigned since to eliminate those problems.
The BL will give you more SPL with a little less SQ.
The Q gives you awesome SQ with better low end.
Soundstream is not very good BTW.
Post Number: 38
You recommend the 2 12" BL's than? If so what should I power them with, Im looking at a Hifonics Brutus 2000 watt for $300. How's that sound?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9858
I run Qs because I like SQ systems. You have to decide if you want more SQ and low end or more SPL.
Hifonics amp are overrated, do not do claimed power and qualitys not great either.
I would get an Audioque 2200d for the amp.
Post Number: 39
See I'm looking for Great SQ but I also want lots of SPL, Iv'e owned a 12" Type X and a 10" Jl W7 and Im looking for twice the SPL. I know nothing abotu Fi, will two Q's powered right destroy the w7 and Type X in SQ and SPL?
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2363
What vehicle is this going into?
Post Number: 40
It's going in a 94-97 cutlass supreme
Post Number: 41
I was also looking into Memphis Audio, how are their subs and amps?
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2553
Memphis subs are not very good imo... with a $ 3000 budget, There are plenty of options including what you are looking into.
3-12" RD Sonances. on a RD 3250 would sound great and get loud. They only need 1.25-1.5 cu. ft each. They broke a few world records in the lanes last year. If you get D2 v.c., run em at 1.34 ohm load.. shound still have plenty of money left over for everything else.
Post Number: 42
I've never heard of them, and the biggest problem is trying to find those subs up here in Canada. Running those 3 subs with that amp, would I need lots of electrical upgrades?
Username: Terra
Post Number: 30
Cascade is 2 hours from Canada
Post Number: 43
So 2 12" Cascade Omegas would have good SPL and SQ? If so what should I power them with?
Username: Mendonmafia
Post Number: 1722
how much electrical do you want to upgrade? 1200 rms is the limit for stock electrical in most cases.
Post Number: 44
Heres what I'm thinking.
Either
2 12" Cascade Omega or 1 15"
2 12" Fi BL or Q or 1 15"
Give me an opinion which sub setup I should do, and what I should power them with. Don't worry bout the electrical. I just want crazy SPL and still good SQ
Username: Snowball123
West Allis, WI
Post Number: 2259
you have to worry about the electrical though. arent the omegas rated at 2000 each, so that's 4000. you cant run 4k on stock electrical.
Username: Hittin1
Post Number: 2559
https://www.ecoustics.com/electronics/forum/car-audio/529460.html
www.rdaudio.net
Kevin Holden or Steve Miller (owner)can get you a good price. or look around and find some used equipment.
http://www.caraudio.com/forum/forumdisplay.php?f=6
http://www.caraudioclassifieds.org/forum/index.php
Post Number: 45
So you say RD's are that good?
And you recommend 3 12" Sonace's?
Any other good model?
If not what should I power them with?
Username: Hittin1
Post Number: 2561
2-12" alpha V.2 would wang
Username: Hittin1
Post Number: 2562
rd3250 at .5 ohm if you got charging upgrades done
Username: Hittin1
Post Number: 2563
along with many other good companies.
Post Number: 46
So two alpha V.2 powered by the RD3250 would wang?
What upgrades would need done? H/O alt? The Big 3 obviously, what else?
What db's am i looking at here? just to give me an idea. I know its hard to judge, but just an idea.
West Allis, WI
Post Number: 2260
cant tell, its about the install. but youd probably need a H/O alt and I'd suggest 2 good batteries. It's not cheap man.
Post Number: 47
Two just normal 12v batteries? Let's say I have the H/O alt and two batteries I also have a kinetik cap. and I had the two alphas powered by the 3250. Is that enough to pound awseome? I think im going to put them in a sealed for that extra SQ or do you recommend ported?
West Allis, WI
Post Number: 2262
I wouldnt suggest just walmart batteries. Maybe a kinetik HC1800 up front and an HC2400 in the back. And dont use a capacitor. I'd also port the alphas if you're looking for SPL, they should still sound good SQ wise ported also.
Post Number: 48
Ok. I think My setup will be two alphas in a ported box tuned around 40hz?? Powered by a 3250 with the Kintetik cells, 0 gauge wiring with a H/0 alt. Anything else to add? And does that sound like a good setup?
West Allis, WI
Post Number: 2263
no, tune lower than 40. go in the 32-34 range.
Post Number: 49
Ok, wasn't 100% sure. I had a 12" type X last sub and tuned a box for it to around there and it sounded sooooo clean and rumbled fairly nice. So these will absolutly kill it right? And is that a good setup?
Post Number: 1726
For batteries if by normal you mean 2 d3100 from powermaster or kinetik 2400s or something along those lines then yes, a normal 12v battery.
I'd save the money for a capacitor and add more wire or battery.
The vehicle and how good an enclosure you build will effect the way it sounds too much to predict how it will sound. Why not build a sealed box and if it's not loud enough go ported. It sounds like you want it loud and should just go ported anyway.
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6265
find some 04/05 mode RE XXXs..
Username: Frkkevin
Post Number: 6266
model*
Username: Denim
SoundSolutionsAudio.com, MD USA
Post Number: 845
Since this topic was originally about Fi and RE, if you had to choose between the two, the engineer that did all the great drivers for RE sold it and has moved on to start Fi. RE has since moved build houses and I believe has gone over seas.
Post Number: 50
I can get a 15" Fi Q for $290 so I think I may do that for now. Will I get good SPL and SQ if I put that in a ported enclosure?
Diamond Member
Post Number: 23244
good choice.
yes in a ported you will get good output and clean sound. you will get good output in a sealed as well.
Username: Frkkevin
Post Number: 6270
you can probably find a used 04/05 XXX 15" for $50-$60 more..
I've not had a Fi sub really impress me yet..
Post Number: 51
Would you say 2 12" 04/05 XXX or 1 15"?
Diamond Member
Post Number: 23246
i heard 2 15" xxx and it was nice. but the fi q sounded just as nice imo.
Post Number: 52
If I got 2 15" in either XXX or Fi Q would I be able to fit them in a 96 Cutlass trunk?
Username: Frkkevin
Post Number: 6271
good lucking finding the 12s tho.. i'd just get two 15s if you can afford it and power them.. worst comes to worse seal them.. then youll have room
Post Number: 53
Ok, so you recommend the 04/05 XXX in 15s. Two of those in a sealed would pound and sound great! What should I power them with?
Diamond Member
Post Number: 23247
yes.
get yourself a nice 3000wrms amp and you are all set. you can put more power than that if you want. just make sure you have a good charging system.
Post Number: 54
Ok, My setup will be two 15" RE XXX older model powered by whatever I find (any suggestions) Thank you to everyone for the help!
Diamond Member
Post Number: 23249
mmats d3500.1
that is assuming you get 2 xxx that are dual 1ohm. if you happen to get 2 that are dual 2ohm then you can get the mmats d3500.05.
that is amp that i would use. i am sure others will have different ideas.
Username: Frkkevin
Post Number: 6275
could always go with strapped aq 1200ds or saz1500ds
