I just moved my box from downstair to upstair and suddenly I ain't getting any pic. Then I found out that my cable wire was broken, so I understand the reason for getting no signal. I just brought new cable and hooked it up but still not getting any pic, but only getting "Scramble or bad Channel" I also re-set the factory setting and then re-scan and still not getting any pic but only Scramble or bad Channel. What should I do next?
Firoz Khan: If I remember correctly, you have a Pansat 2500 clone converted to 2700 using PUFF_LZMA BIN 207. There is a problem with this BIN at times when you switch off and you lose channels. You should install PUFF_LZMA BIN 207V2 - This BIN has overcome the "Scrambled channels" problem.
Hey Guys everything is working fine. When I went to Navragation 2 and all the keys were change, so I input the correct ones and it started working. So wanted to say thank you to both for u for helping me out.
