Username: Bosanel Calgary,
Alberta
Post Number: 13 Registered: Feb-07
Friday, February 13, 2009 - 03:05 GMT Dish Network viewsat xtreme & platinum both doing the same newest bin loaded what could be wrong? Thanks
Username: Plymouth Canada
Post Number: 7505 Registered: Jan-08
Friday, February 13, 2009 - 04:04 GMT Annel check if your dish is right, because all viewsats are up on latest file.
Alberta
Post Number: 14 Registered: Feb-07
Friday, February 13, 2009 - 04:34 GMT Yeah, I know, I called a few friends too, and they weren't having any problems at all.. Maybe its my satellite positioning? could it be cables? How about my settings? Eek I'm confused..
Username: Pirate92 Post Number: 17 Registered: Sep-07
Friday, February 13, 2009 - 12:48 GMT I am seeing the same problem on VS-Ultra Sound/quality good but no audio/video using the 0903 file
Post Number: 7508 Registered: Jan-08
Friday, February 13, 2009 - 12:58 GMT Anel, Pirate Sorry I had not see that the signal and quality are good. Re load the latest bin file, if it not work do a factory default then load the factory bin and satellite info from viewsatusa.com then load the latest bin, now rescan all satellites and it will work now.
Username: Pirate92 Post Number: 18 Registered: Sep-07
Friday, February 13, 2009 - 13:11 GMT Hello Plymouth: I just did the following and no luck. 1.Factory Default. 2. VS_Ultra_V014 factory bin. 3. SAT info for E7-119, E10,11-110 LNB Power = ON LNT TYPE = OCS-DP LNB FREQ = 11250 22KHZ = off TP Freq = 12224 DiSEqc = Port 1,2 Motor = off Legacy SW = None 4. Latest bin VS_ULTRA 090203 5. Rescan I can only see the channel 100 and 103 coming, rest of them are no sound/video. appreciate your help.
Username: Pirate92 Post Number: 19 Registered: Sep-07
Friday, February 13, 2009 - 13:15 GMT My Auto TP is set to off and Auto Roll is set to off also under menu->User Setting -> option 2
Post Number: 7509 Registered: Jan-08
Friday, February 13, 2009 - 13:54 GMT Pirate On Viewsat you must keep always the autoroll "on" and wait until the picture come. If it not work we will try another solution.
Post Number: 7510 Registered: Jan-08
Friday, February 13, 2009 - 13:56 GMT I can see that you use OCS-DP. Is it a DN dish?
Username: Pirate92 Post Number: 20 Registered: Sep-07
Friday, February 13, 2009 - 13:57 GMT yes
Username: Pirate92 Post Number: 21 Registered: Sep-07
Friday, February 13, 2009 - 13:58 GMT VS Auto Roll options are following: BV, DN, Off & All. which one should i pick ?
Post Number: 7511 Registered: Jan-08
Friday, February 13, 2009 - 14:00 GMT Put it on all even if Bev is down.
Username: Pirate92 Post Number: 22 Registered: Sep-07
Friday, February 13, 2009 - 14:02 GMT I set it to All and picture came Thank you Plymouth
Post Number: 7512 Registered: Jan-08
Friday, February 13, 2009 - 14:06 GMT Pirate You are Welcome
