Gold Member Username: MendonmafiaUSA Post Number: 1703 Registered: Aug-06 | I have the chance to trade my fully loaded btl 15 for an ap axis 15" Just wondering which you guys think will get louder. assuming ideal box for each and 3k rms. i know the ap will sound better and dig lower but which will be louder. also the ap will run in a smaller box correct? |
Silver Member Username: DenimSoundSolutionsAudio.com, MD USA Post Number: 844 Registered: Nov-06 | How do you know the " ap will sound better and dig lower" ? |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2349 Registered: May-07 | IIRC Jake Papa was doing 145's daily in an SUV of around 2.5~3k on a single Axis. The Axis should get alot louder down low. I haven't heard either sub tho. |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2350 Registered: May-07 | IIRC Jake Papa was doing 145's daily in an SUV of around 2.5~3k on a single Axis. The Axis should get alot louder down low. I haven't heard either sub tho. |
Gold Member Username: MendonmafiaUSA Post Number: 1704 Registered: Aug-06 | i guess i dont know but just from reviews. i really just want to know which will be louder for a daily setup. this seems like a good deal to me and i want to know what yall think |
Gold Member Username: RedlinerWilmington, Ma Post Number: 4944 Registered: Jun-05 | i dont think you could go wrong with either. I would say personnel prefrence after you listen to both to close to call. I have never heard either so cant actually comment on which is better |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2444 Registered: May-07 | Has anyone heard if AP is out of business. I heard they are. I am not a big fan of FI so it would be an easy choice for me, but you can not ignore the accomplishments and reputation of FI's monster (BTL) They get loud as hell and are being used by a lot of reputable builders(S. Meade ect...) I do know that the axis does great in smaller enclosures and I wanted to try a pair of em. I guess a good question would be, is your BTL an older sub(known to have tinsel slap issues) or a new fixed tinsel sub? Does that make sense? for the record, I vote Axis. |
Gold Member Username: MendonmafiaUSA Post Number: 1705 Registered: Aug-06 | its the new btl with the new motor. the tinsels go under the spider so theres no way for them to slap. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2453 Registered: May-07 | Are you not happy with the BTL? Are you trying to save space? Doi you know or trust the interested party? |
Gold Member Username: MendonmafiaUSA Post Number: 1706 Registered: Aug-06 | Are you not happy with the BTL? Are you trying to save space? Do you know or trust the interested party? The BTL is brand new i have never even heard it so i cannot say weather or not i am satisfied. Only reason i want to trade is because if i go the BTL route then i am stuck with one 15" BTL unless i trade it or sell it for somthing else, i do not have room to run 2 15" btl's due to the large diameter magnet. if i get the AP i have the ability to fit a second one if i want to. I guess you could say im trying to save space but really im trying to maximize the efficiency of the space i have. as for trust in the other party i do not know him personally but he has ref's on ca.com. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2455 Registered: May-07 | do it, sounds like you have every reason to do it. Good luck Mark. Hope it works out for you. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2456 Registered: May-07 | i'de get pics with username, date, and voice coil readings, if I were you.. JMHO |
Gold Member Username: MendonmafiaUSA Post Number: 1707 Registered: Aug-06 | Has anyone on here heard both subs? I just really dont want to be making a mistake. just looking at the btl i feel like i need to hear it but i will sacrifice the pleasure if the AP is really worth it. can anyone just give me the confidence to tell me that i wont be missing out on much spl if i go with the AP. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2461 Registered: May-07 | i've heard the BTL fully loaded and the Axis. Both were mutiple subs setups, soooo. They were both loud as fu<k. The Btl was a daily setup, but wasn't very musical imo. The Axis's were in a f@rt box. Take it for what it's worth. |
Gold Member Username: MendonmafiaUSA Post Number: 1708 Registered: Aug-06 | tru that well i guess im going to do it since i can have room to upgrade later on down the road and because i will save some trunk space using the AP. Gonna be hard for me to let the btl go with out ever hearing it tho. but it will probably be worth it. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2463 Registered: May-07 | i feel ya. i may sell the jugg w/o hearing it, gonna be hard to do. |
Gold Member Username: TejcurrentPost Number: 1700 Registered: Apr-07 | Normally when people trade it's because it's beneficial to them. I'd look at the other guys motivation for wanting the BTL. Just a thought. |
Gold Member Username: MendonmafiaUSA Post Number: 1710 Registered: Aug-06 | he says he wants to do an all out spl setup. Which makes me want to keep the btl cuz maybe its louder. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2482 Registered: May-07 | MArk- even IF the BTL is slightly louder, 2 Axis would be no contest. and you CAN'T do 2 BTL's. botton line is it is up to you. |
Gold Member Username: MendonmafiaUSA Post Number: 1711 Registered: Aug-06 | Very true. well the guy has not gotten back to me yet so the deal might be off anyways. i asked him to send me pics of the surround to probe it was never mounted like he said. there no real way to tell visually if its been powered or not. |
Gold Member Username: MendonmafiaUSA Post Number: 1712 Registered: Aug-06 | he got back to me he said hes going to take pics of the surround to show it has not been mounted. u guys might know him mmatsdude |
Gold Member Username: MendonmafiaUSA Post Number: 1713 Registered: Aug-06 | turns out he got it bnib off ebay for 300 shipped in late january so i think im getting a legit deal. |
