Hdtv to sv360
Username: Rockman169
Post Number: 58
going to buy my girl friend a tv for the bedroom for valetines but all i can find hdtv .was just wondering if the picture would be poor or look funny thanks
Username: Mrgreg
Ont. Canada
Post Number: 308
Rockman, You mean your buying yourself a new HDTV. You better hope your doing the right thing because if I where her I would tell you to shove that as far up your a** as it would go. Just my opinion.Good luck.
Post Number: 59
no acually, Im a fisherman and sleep aboard a boat most nights. How is the picture quality if hooked up to a fta receiver
Username: Pleasersmiles
Post Number: 79
Panasonic HDTV connected to a Pansat 3500 receiver. Picture is excellent.
Username: Riconissan
Post Number: 35
Yeah grow a pair. SHE should be buying you a new TV Rock!
