Is this sub good?
Username: Stevetxbc
i was told kicker sucks, so what about this?
HIFONICS OLM2415 15" 4800 WATT
* 15-Inch DVC Subwoofer
* 4800 Watts!
* 2400w RMS Rated and tested
* For Ported or Sealed Enclosures
* 1-Ohm, or 4-Ohm Operation each sub (2 subs will run @ 2 ohms or .5 ohms)
* 76mm Dual 2-Ohm Voice-Coils
* 160 oz. High-Energy Magnet
* Fiber-Glass Infused FEA Structured Cone
* Die-Cast Aluminum Chrome Speaker Frame
* Multi-Layer High-Temp VC
* Front-Plate & Voice-Coil Cooling
* Double-Laminated Integrated
* Spider Tinsel-Lead Design
* 25.4mm / 1" Hi-Excursion Surround
* Push & Insert Wire Terminals
if this is a good sub, what amp would you guys recommend?
Username: Vivi2000
Owosso, Mi
Post Number: 109
I personally would not get a hifoncs sub. Tell us your budget total, what you need(amp sub etc.), do you want sound quality or just a loud system. Also about how much space you have to work with.
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2492
I would NOT go with Maxxsonic subs.
Username: Stevetxbc
i was trying to keep it under a grand for stereo subs box amp and wiring. and its going in the trunk of a honda accord. i want good sound quality but also to hit hard.
Username: Hittin1
Post Number: 2497
SUBS:
SI Mag
Fi Q
RD Sonance
RE SX
AP REVO
new amp
AQ1200
RD 1000.1
used
pdx 1000.1
RF BD1000
sundown saz 1500
many other great amp possabilities
fishercustoms box
HU
Eclipse
Alpine
Pioneer Premier
Kenwood
This should get you started. This by NO means is a complete list.
Diamond Member
Post Number: 23229
chad's good, bad, and ugly subwoofer list.
good.....tba
bad.....tba
ugly....
hifonics
Username: Snowball123
West Allis, WI
Post Number: 2184
agreed.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9759
yea mark about covered this one.
Username: Terra
Post Number: 20
Mark that list seems more SQ orientated. The Hifonics sub, from the description, seems more spl orientated. Maybe suggest some spl/daily subs?
BTL, HDC3, MT, Omega, 9500 series..
Username: Hittin1
Post Number: 2503
RE MX
Alpha w/flatwind
Sonance SPL version
IA DP
AP axis- used
Treo SSX
DC lvl4XL
mmats Juggernaut 12"- I have 1 for sale
many others as well
problem with this in power needed and keeping under your budget. (unless u find a good used deal)
