Child Gayson There is nothing wrong in asking. We all understand that your total experience is backwards, like Arabic writing - and hence it is difficult for you to understand simple straight things, straight questions and experiences. Perhaps it would be good for you to think twice before jumping in to answer straight questions, always knowing that any statement you make would be coloured or twisted by your backward experience as in Arabic.
Hi Nalin, I had ask you about what satellite receiver i should buy and you kindly recommend a few including sonicview 360 premier, well i have it now but i need your help again, first what satellites do i need to download for the Indian and American channels and another thing is were do you go to put the codes to get the channels to work, I knew how to do that with my Foretec Classic but this is totally new to me,any help would be greatly appreciated plus I am pretty rusty. Thanks in advance.
Indian channels are on: 118.7W Anik F3. You need a 33" dish and a special 118/119 LNB. There are about 43 and only about 20 are available now - the rest are already under Nagravision 3 security and you will need to wait for a while for those. ZGUJ and all other regional language programming and all Pakistani channels are a victim of N3 security.
Some Indian channels are also on 61.5w - Echo 3, but they are being removed from it.
There is going to be a complete change over to N3 soon, and all your efforts will then come to Nil till N3 is hacked.
Hi Nalin, So are you saying that there are no channels available to watch at this time? and the dishes that I have are no good, how about the American channels, would I need to change the dish for that too. Another question I have is that I have a sonicview 360 premier but I cannot find where to put the codes in like I use to do with Fortec Classic, could you help me on that. Hope to hear from you soon.
Hello Nalin Could you tell me how to install the bin and the keys on the Sonicview 360 primier, I knew how to do it with my Fortec Classic but I looked all over and couldn't find it on the Sonicview. Thanks, you are a great help.
hey it is very easy to load files on sv360 what you will need a usb drive.go to www.ftabins.net and download the latest file to your desktop,then unzip that file using a program like winrar.insert usb drive in your computer and send unzipped file from computer to usb drive.now insert usb drive into sv receiver and go to menu and mass usb storage.download the file to receiver.do not remove the usb drive until download is complete.on your second question,i don't know how many or what kind of dish's you have installed,i have a feeling you should be able to use them
