PUFF_LZMA_207 is down, wait for new bin
Username: Imauser
Post Number: 139
Puff_Lzma_207 is down. wait for a new bin
Username: Viruscauser
Leesburg, Georgia
Post Number: 978
LZMA 207 Bin for the 2500>2700 working great here. Try a Hard Boot.
Username: Nydas
Post Number: 14404
If that does not work, try a rescan.
Username: Nydas
Post Number: 14409
Also note that there is PUFF_LZMA version 2 out for the past 2-3 days which corrects some of the problems you are seeing.
Username: Hangon
Post Number: 77
Puff_LZMA V2 works for me, I had some trouble today with Scrambled Channels. This is what I did:
factory reset
choose your Sats and settings
Scan Sat's DO NOT Blind Scan
DO NOT use Channel Master to reload previous Channels
Last turn off auto-roll
You may see Scrambled for a minute
until things load
Enjoy, for now...
Username: Letmeon
Post Number: 274
Last night, OK ...........
Only had freezing on channel changing. Just had to power off and restart.
Otherwise PUFF LZMA 207 working fine on
my pantec ultra mx
Username: Jaye50
Post Number: 157
fm.....don't you think it would have been prudent to do some research before you came on here trying to give others advice and erroneous info....
Username: Kaanwal
Ont Canada
Post Number: 51
Hi,
I m sorry i m bit lost, cud'nt find puff-lzma v2, where can i find it?
Username: Nydas
Post Number: 14410
Essential kit 103 for conversion to 103 LZMA boot Kit.
This is the new change recommended.
Convert to PUFF_LZMA. There will not be any more PUFF
PUFF_LZMA_207 V2 BIN in separate file
Alternative PUFF_LZMA link
Download and unzip into separate directory.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Kaanwal
Ont Canada
Post Number: 52
Thanks Nalin
