Underpowering a sub = blown?
Username: Mcdstvn
Palm Coast, FL United States
Post Number: 10
I was reading reviews on some of the things I Was looking at, and a review said something that I wasn't quite sure was right, that underpowering an amp could cause it to blow...
Anyone know if this is accurate?
Sorry if it seems like a ridiculously simple question, I'm new to this
Username: Kissdaredevil
Post Number: 66
I've never heard of underpowering an amp. If you mean underpowering a sub, I have heard this. I have been told that if you underpower a sub you can damage the voice coil.
A pic is worth 1000 posts!!
Post Number: 19780
"I have been told that if you underpower a sub you can damage the voice coil."
Huh?
The only way you can damage a sub when "underpowering" it is when you max the gain and/or bass boost to compensate for the lack of output. THAT will cause distortion and THAT is how you cause damage. It's been said so many times b4. If underpowering a speaker damages it then you would damage it everytime you turn your volume down.
A smart/conservative setting on the BB and gain can actually allow you to run MORE than recommended power and a dumb setting on the same can cause damage at below recommended power.
It's really all up to the man behind the curtain.
Username: Mcdstvn
Post Number: 11
well, man behind curtain had his first system in and left all the settings where the guy who hooked it up left them...
2 10" http://www.evosoft.dk/xtreme/xtreme_subwoofers.html
powered by jensen 300 watt amp, bridged to play each at 4 ohm.. = damage?
lows halfway up
highs turned all the way down
and mids about a quarter up?
I'm assuming that's what the third knob was.
Username: Glasswolf
NorthWest, MI USA
Post Number: 12406
http://www.bcae1.com/2ltlpwr.htm
/thread
