Gold Member Username: PlymouthCanada Post Number: 7437 Registered: Jan-08 | PBS, PBS World, V-me and Create with a very very good picture Quality. Enjoy |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 3987 Registered: Oct-06 | Plymouth These channels used to be on AMC 3 at 87.0°W All 8 TPs moved from 87W to new orbit location 125W |
Gold Member Username: PlymouthCanada Post Number: 7438 Registered: Jan-08 | Yes King you are right I get 16 channels but only one with sound. Is there a solution for get those channels with sound? |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 3989 Registered: Oct-06 | They all should come on with sound Yo may have to try with a real FTA receiver |
Gold Member Username: PlymouthCanada Post Number: 7439 Registered: Jan-08 | I have a true FTA receiver Vs Ultra |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 3990 Registered: Oct-06 | Then why it won't have sound? |
Gold Member Username: PlymouthCanada Post Number: 7440 Registered: Jan-08 | It happen on few satellites |
Bronze Member Username: Tdti1Post Number: 94 Registered: Mar-05 | Many channels are ac3 audio, your receiver will have to have ac3 audio pass, if so hook it up to a amp with digital audio and all should be fine, if you have a dvb HD receiver it should decode the ac3 on it's own. Oh and if you find good channels open and not listed on lyngsat please keep them to yourself, as public posting gets channels encrypted. |
Gold Member Username: PlymouthCanada Post Number: 7441 Registered: Jan-08 | Teddy Thanks i will try on my surround. Yes you are right many channels come encrypted, good point. |
Silver Member Username: BernardmiPost Number: 334 Registered: Dec-07 | You would need an external Sound Blaster Audigy AC3 converter Plymouth. I used to listen to V-me myself on AMC3 to learn Spanish. You do not need the PC card nor the remote control unit. Just the box hooked to SPDIF output of your Viewsat and to your sound system. I bought mine on eBay for peanuts. http://jp.creative.com/products/product.asp?category=1&subcategory=204&product=4 925&nav=artwork |
Silver Member Username: BernardmiPost Number: 335 Registered: Dec-07 | Wow !!!! I bought mine for peanuts but not anymore.... I just glanced at eBay and they all ask for $150 for the unit !!!! I paid mine $40 !!!! What triggered this overpricing ???? Ah I should know..... They all are for sale by wall street execs !!!! |
Gold Member Username: PlymouthCanada Post Number: 7443 Registered: Jan-08 | Bernard I don't have a S/PDIF on my home theater but it is the time to upgrage for a new Home theater, mine is a older. |
Silver Member Username: BernardmiPost Number: 337 Registered: Dec-07 | You will have fun listening to Spanish Sesame Street in Dolby Surround. Just imagine the noise when cookie monster crunches food !!! |
Silver Member Username: BernardmiPost Number: 338 Registered: Dec-07 | |
Gold Member Username: PlymouthCanada Post Number: 7444 Registered: Jan-08 | Good one Bernard LOL |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 3992 Registered: Oct-06 | "Many channels are ac3 audio, your receiver will have to have ac3 audio pass" MPEG-2 receivers can decode AIF or AC3 all ISO standards AIF is uncompressed audio AC3 is digital dolby compressed Surround sound that's different That's an encoded signal within AC3 L&R plus up to 4 subs plymouth Don't go crazy No need for special audio out No SPIDF no optical Yor basic L/R port is all yo need Like I told yo some bins cause audio problems Try a real virgin FTA receiver Yor receiver lost its virginity somehow |
Gold Member Username: PlymouthCanada Post Number: 7450 Registered: Jan-08 | King After a check with Viewsat the Vs Ultra can't provide AC3 audio on RCA output but on S/PDIF output. I have a eye on a new Home theater with this input on it. Yes my receiver lose his CHERRY Are you able to get it on your Xtreme. |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 3993 Registered: Oct-06 | I get AC3 on Xtreme and on Visionsat Most channels operate on AC3 for less bandwidth Infact very few channels do AIF audio "After a check with Viewsat the Vs Ultra can't provide AC3 audio on RCA output but on S/PDIF output. " Not true MPEG-2 has the option to pair with AC3 or AIF format |
Bronze Member Username: BoquackPost Number: 15 Registered: Mar-08 | Lets not for get about White springs TV at 129W! "Cuse Kings gonna sock it to ... the Harper Valley PTA" - Jeannie C. Riley. |
Gold Member Username: PlymouthCanada Post Number: 7454 Registered: Jan-08 | King are you able to get sound on AMC 21? |
Gold Member Username: TapemanNew York Citay in-HD, NY Post Number: 3994 Registered: Oct-06 | I don't have a connected 33" dish at this time But it's not an AC3 issue to answer yor question Yo may wanna call the provider on Monday It's Free to Air So yo should get sound Not unless yor current bin is doing something to the Audio I did came across that before on Visionsat just few days ago I had to load a different bin to fix the audio For example Visionsat bin V216 had Audio problems Same day they came back with Audio fix bin V217 Check NORWFTA.COM |
Gold Member Username: PlymouthCanada Post Number: 7460 Registered: Jan-08 | King I have never get any channels in AC3 with my viewsat Ultra, i just check with viewsat today and the guy says that the Ultra doesn't have the decoder for it and I need to use the S/PDIF output for it. If anybody can get it with Ultra please reply here. |
New member Username: RiconissanPost Number: 7 Registered: Feb-09 | It is possible that the person that you contacted at VS gave you bad information. Also, are you sure it is broadcast in AC3? |
Gold Member Username: PlymouthCanada Post Number: 7464 Registered: Jan-08 | Rico Few Free to Air satellites Provide both choice with AC3 and standard, since i have this receiver, I have never get sound on channels with AC3. But I will just buy a new Home Theater with the S/PDIF and give a try and come back with the result. |
New member Username: RiconissanPost Number: 10 Registered: Feb-09 | Sounds good (pun) lol. I was just trying to eliminate any issues with the BIN. Sorry I am fixed @ 110, 119 With Prv7000 so I could not verify the signals you are receiving. |
Silver Member Username: ElmoxpOttawa, Ontario Canada Post Number: 261 Registered: Jun-06 | and any news about 123w? |
Gold Member Username: PlymouthCanada Post Number: 7473 Registered: Jan-08 | Elmo What you want to know on Galaxy 18 123W? This satellite provide many interesting local channels Free to Air |
Bronze Member Username: Little_bearSudbury, Ontario Canada Post Number: 96 Registered: Mar-08 | C/P Author Thread: Galaxy 18 at 123.0°W True FTA channels FTA TESTER Silver Member Username: Jay_w_grayson Prague, Oklahoma USA Post Number: 449 Registered: Jul-08 Posted on Wednesday, February 04, 2009 - 11:40 am: -------------------------------------------------------------------------------- Galaxy 18 at 123.0°W Galaxy 18 (Formerly known as Galaxy 10R Satellite Channels/ Frequency/ Polarity /Symbol Rate WBLU-LP (Lexington) 11720 V 27692 KLRA-LP (Univision - Little Rock) 11720 V 27692 WNYI-TV (Syracuse) 11720 V 27692 TeleFormula 11720 V 27692 KDEV-TV (Cheyenne) 11720 V 27692 WUJF-LP (Lake City) 11720 V 27692 KXUN-LP (Fort Smith) 11720 V27692 KWCE-TV (Alexandria) 11720 V 27692 KEYU-LP (Amarillo) 11720 V 27692 KAMT-LP (Amarillo) 11720 V 27692 WNGS-TV (Buffalo) 11720 V 27692 KWWF-TV (Waterloo) 11720 V 27692 KUOK-TV (Univision - Oklahoma City) 11720 V 27692 KUTH-TV (Univision - Logan) 11720 V 27692 KEGS-LP (Las Vegas) 11720 V 27692 KFDF-TV (Eureka Springs) 11720 V 27692 Veterans Affairs Knowledge Network 3 11732 H 13240 WUMN-TV (Univision - Minneapolis) 11800 V 26657 KCBU-TV (Provo) 11800 V 26657 KUTF-TV (TeleFutura - Price) 11800 V 26657 KUWF-LP (Univision - Wichita Falls) 11800 V 26657 KTVC-TV (Roseburg) 11800 V 26657 KQUP-TV (Spokane) 11800 V 26657 WMQF-TV (FOX - Marquette) 11800 V 26657 KKYK-TV (Eureka Springs) 11800 V 26657 KWBF-TV (My - Little Rock) 11800 V 26657 } KDEV-LP (Aurora) 11800 V 26657 KWKO-TV (Univision - Waco) 11800 V 26657 WGMU-TV (My - Burlington) 11800 V 26657 WPXS-TV (Mount Vernon) 11800 V 26657 WUJF-LP (Lake City) 11800 V 26657 KWBM-TV (My - Springfield) 11800 V 26657 Daystar TV 11800 V 26657 Research Channel 11805 H 4580 UWTV - University of Washington TV 11805 H 4580 KKFQ-CA (Univision - Yakima) 11966 V 13021 KTWO-TV (ABC - Casper) 12104 V 2222 KFDF-CA (UPN - Fort Smith) 12114 V 4444 |
