Need ur guys help wid FI products
Username: Tambule_pinoyski
Bustos, Bulacan Philippines
hello to every1 here...currently im here in philippines and im going to visit in the u.s l.a in march, subs and ampli is cheap in u.s than here in my country.. so sirs can u help about fi product and what kind of amplifier can i use it and enclosure, i listen sme hiphop, rock and rnb, here in my country i never heard bout FI but sme of my friends they told me that fi is better that l7..here i have a 2 l7 10inch and zx1000.1 for that..so guys help me i want to try something new. My ride is honda civic sir its like si in u.s but its 4door. i want a one 12' sub...tnx..is my english correct?.hahaha.
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2450
How much do you want to spend on sub and enclosure?
Are you gonna use the same Kicker amp?
Username: Hittin1
Post Number: 2451
Oh and By the way, you English is better than 50% of our new posters, and They are from here. I could understand your sentences and you use punctuation. lol Welcome to Ecoustics.
Username: Surferdude9371
Get loud or go home....
Post Number: 1659
what exactly are you looking for a loud sub (spl) good clear sound (sq) or a mix of both (sql)? whats your budget? and yes are you using the same amp?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9735
2 Fi Qs and 2000w amp = awesome
ahmmm.tnx for the warm welcome sirs..anyways 70%spl /30%sq?..what is the best guys?..do u think my ampli is good enough for that or am gonna buy a new 1?...i prefer 1 sub only for the meantime, bec of the space, but i want a good enclosure?..is Q better?.and what is the best amplifier for Q lines, mybe nxtyr when i come bck to u.s i buy another FI sub...tnx sirs..
Username: Nd4spd18
Philadelphia, PA
Post Number: 9736
Well then a BL would be what your looking for, more SPL, 1000w is good.
Username: Hittin1
Post Number: 2462
Are you stuck on Fi? there are other companies out there that can fit your needs.
M.S so il get the FI BL but what ampli should i use? can i still use my zx1000? o buy a new 1?or old ones?.my budget is around 200 to 400 u.s, new or used bt made in u.s. and what enclosure shud i use?.for the BL......whats ur idea sir mark?..what sub is the best for u?..tnx guys.
Username: Hittin1
Post Number: 2474
RD Sonance SPL version.
Treo SSI
RE SX
many others would work
Username: Quirky
SA, Texas
Post Number: 372
Your zx1000 should work well with the FI BL.
By the way- Don't expect to find Fi or some of these other brands in stores when you come to the US. Manny are sold online only.
You can visit the Fi website at
www.ficaraudio.com
tnx sir..but can u give me a gud spec for fi BL enclosure?.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9753
You need to get a dual 1 ohm BL if you want to use your kicker amp with it.
Fi has box size and tuning specs on the website.
ah ok..what if i use this amp "Audison LRX 1.400 - Audison 1 Ch 900 Watt Amplifier" but its underpower?..this will be gud or the zx?.and i went to their website thers some optional specs in the BL like P champer, flatwind etc. whats up wid that anyways, i have no idea wit this 1..what should i choose...tnx. sir.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9756
That audison is a very good amp also but its 1 ohm stable, so you need a dual 2 ohm sub for that.
Dual 1 ohm sub for the kicker amp. So decide what amp you will use.
Those extra options on the BL are power handling upgrades. With 1000w you won't need any of it.
ish...im getting cunfuse, which 1 is gud BL 1 ohm o 2ohms?..this is my plan!.?,
-LRX 1.400 - Audison 1 Ch 900 Watt Amplifier
1 FI BL12
-SRX 4 - Audison 4 Ch 340 Watt Amplifierier
-2 sets of CTX65CS - Image Dynamics 6.5 Components
Phoenix gold e215ix
is this gud enough o shud i use my old zx1000.1 and zx350.4 channel amps.?...
Username: Hittin1
Post Number: 2488
if you already have the kicker amps, keep them, or sell em to me. lol Nothing wrong with kicker amps.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9758
The audison amp is 1 ohm stable so you need a dual 2 ohm sub
The kicker is 2 ohm stable so you would need a dual 1 ohm.
You MUST get the correct ohm coils for watever amp you will be using so you have to choose the amp before you get the sub.....
Post Number: 10
copy that M.S..so does this set up good enough?.
1 FI BL12 2ohms
Phoenix gold e215ix
Username: Nd4spd18
Philadelphia, PA
Post Number: 9780
That would make a great system yea.
Except the rears aren't needed... more on that
http://www.glasswolf.net/papers/rearfill.html
