Week signal
Username: Marbie6
Post Number: 31
you ask what size antenna i am using
i am using a six foot fibre glass dish. the 119 signal is weak, i only recieve signal from 4 am and by 8am the signal is lost. i have a lifetime ultra fortec star reciever and i am living in the caribbean,jamaica.
the same lnb that i used to pick up 110 is what i use to pick up 119 which is very weak while 110 is very strong.
Username: Ddluv
Every city , All All
Well ,did u rescan the sats ? Plus make sure u set 110 to port 2 & 119 to port 1 .Then after u adjust those ports on the stb.Than scan them one at a time .
Username: Odc
The 110 EIRP is much greater at your location than the 119. You will therefore need at least a 10 dish to prevent the fading.
Username: Marbie6
Post Number: 32
what is stb and port?
