Ciel 2 Transponder Frequencies?
Username: Dvcrazy
Does anyone have the transponder frequencies for Ciel 2 at 129W? I can't seem to get a complete list anywhere.
Username: Ddluv
Every city , All All
Try this :Go to channel scan, make sure NETWORK SEARCH is ON, delete all transponders with the exception of 12224 .. then edit it to 20000 SR , V , 5/6 FEC , DVB ... once done, hit OK to scan.. it will automatically scan in all transponders in use, their correct settings, and all channels. As of this moment, there are 32 transponders and 366 channels. Don't worry about deleting channels first, when you delete the transponders, they go too.
Good Luck & I hope this works ????
Username: Dvcrazy
I appreciate the quick response but I need the freequencies. I don't have the ability to do a blind scan. I'm using s/w that requires the configuration and specific frequencies of the satellite.
Username: Plymouth
Post Number: 7434
rick
Ciel2 is in KA Band satellite, so you can't get nothing on this bird with your FTA receiver.
The channels Loulou give to you come from Echo 5.
Username: Dvcrazy
I'm not using an FTA receiver. I'm receiving Echo 5 but there is a switch going on to Ciel 2.
Username: Link119805
Post Number: 49
rick...try this and let us know:
1, 12224,V,20000,2/3,QPSK
2, 12239,H,21500,2/3,Turbo-8 Inactive
3, 12253,V,21500,2/3,Turbo-8 Inactive
4, 12268,H,21500,2/3,Turbo-8 Inactive
5, 12282,V,20000,5/6,QPSK
6, 12297,H,21500,2/3,Turbo-8 Inactive
7, 12311,V,21500,2/3,Turbo-8 Inactive
8, 12326,H,21500,2/3,Turbo-8 Inactive
9, 12341,V,21500,2/3,Turbo-8
10,12355,H,21500,2/3,Turbo-8
11,12370,V,21500,2/3,Turbo-8 Inactive
12,12384,H,21500,2/3,Turbo-8
13,12399,V,21500,2/3,Turbo-8 Inactive
14,12414,H,21500,2/3,Turbo-8
15,12428,V,20000,5/6,QPSK
16,12443,H,20000,5/6,QPSK
17,12457,V,21500,2/3,Turbo-8
18,12472,H,21500,2/3,Turbo-8
19,12486,V,21500,2/3,Turbo-8
20,12501,H,21500,2/3,Turbo-8
21,12516,V,20000,5/6,QPSK
22,12530,H,21500,2/3,Turbo-8
23,12545,V,21500,2/3,Turbo-8
24,12559,H,21500,2/3,Turbo-8
25,12574,V,21500,2/3,Turbo-8
26,12588,H,21500,2/3,Turbo-8
27,12603,V,21500,2/3,Turbo-8
28,12618,H ,21500,2/3,Turbo-8
29,12632,V,21500,2/3,Turbo-8
30,12647,H,21500,2/3,Turbo-8
31,12661,V,21500,2/3,Turbo-8
32,12676,H,20000,2/3,QPSK
Username: Jay_w_grayson
Prague, Oklahoma USA
Post Number: 456
Thread: Ciel 2 Transponder Frequencies?
rick
Username: Dvcrazy
Posted on Thursday, February 05, 2009 - 01:12 pm:
rick
Ciel 2 was Launch on December 10, 2008
operating from Orbit position 129.0°W
its 32 Ku band transponders will deliver
high-definition and other TV services
throughout North America.
As of now there are no TP Frequencies available.
Username: Dvcrazy
Steve M. Thanks!
I was able to scan. Some of the inactives were active but from what I understand TP's 1-16 are the spot beams and most likely I'm in a different location.
Post Number: 461
rick...your thread Does anyone have the transponder frequencies
Are you looking for Ciel 2 at 129.0°W
There are no TP Frequencies listed for this Bird Ciel 2 © Lyngemark Satellite, last updated 2009-02-03 here is the Link see for yourself.
http://www.lyngsat. com/ciel2.html
If you are looking for EchoStar 5 at 129.0°W as Steve M. has listed above
they are all listed at
http://www.lyngsat. com/echo5.html
Username: Plymouth
Post Number: 7476
Steve M is right
Ciel 2 have 32 TPs and HD channels immigrated on this Bird.
FTAss grayson learn, learn
