Nalin Nyda where can I find HD channels
Username: Crazycool
Post Number: 28
Nalin what satellite's should I blind scan to get high definiton channels your imput will be greatly appreciated thanks in advance.
Username: Nydas
Post Number: 14339
Do you have a HD receiver?
Where are you located?
Username: Crazycool
Post Number: 30
I live in los angeles and as I stated in my last post Iam going to get the pansat 9200hd because I just aquired a 46" samsung.
Username: Nydas
Post Number: 14340
Echo 5 at 129W has a lot of HD.
There are some on 110 and a few on 119.
If you are interested in Indian channels, then go for Dish pro 1000+ with 110/118/119/129
Otherwise get Dish pro with 110/119/129
Username: Plymouth
Post Number: 7430
crazycool
Here is the list of HD bird and all channels available.
http://www.lyngsatDOTcom/hd/index.html
replace DOT by "."
