Help dialing in comps
Username: Surferdude9371
Get loud or go home....
Post Number: 1633
I FINALLY 10 months later have installed my cdt comps and the sound and imaging is great but the tweets are deafening at volume 20 (and i listen usually at 26) how can i turn them down without effecting the mid woofers?
Username: Snowball123
West Allis, WI
Post Number: 2115
Are you using the eq on the HU. I would say go in and turn the eq down at the higher frequencies. Idk if that'll work, but thats my thought.
Post Number: 1635
as in the treble?
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2379
if thats all you got as far as settings on the HU. What model HU are you using?
Post Number: 1636
kenwood dnx5120 it has a lot of settings they are just jibberish to me
West Allis, WI
Post Number: 2116
dont you use the EQ on it. I'm not talking about treble.
Username: Big_edge_head
Milwaukee, WI
Post Number: 3425
There should be a switch on your crossovers for the tweeter like +2db,0,-2db. I'm not sure if CDT has that or not though.
Post Number: 1637
hmmm ill take a look thnx stupid question but i wanna move it towards the neg right?
West Allis, WI
Post Number: 2120
si.
Post Number: 1638
thnx
Username: Nd4spd18
Philadelphia, PA
Post Number: 9686
Depending on which CDT crossovers you have, some have a a +/- 3 db switch.
I run my DRT-25 tweets at -3 db. They are not harsh at all, sound very good but they are loud, were too loud for the mid.
Post Number: 1640
ya they are very deafening the switch is just inside the cover?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9695
Yep it will be obvious if they have it.
Post Number: 1641
thanks
Username: Drant19
DUB-C, TX
Post Number: 1400
which xover do you have M.S.? i dont think the 560 has the switch...
maybe i over looked it.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9699
I have the 480s. I don't think the 560 has the switch either.
Username: Exige
CDT, Audiopulse Dealer
Post Number: 739
Hey email me for any other questions you have Patrick and I'd be happy to help you out. There's no switch on the 560i crossover which (if I remember correctly) is what you have. Simply use the image tweeter output rather than the main tweeter output. This will give you a -3dB drop in the output.
If you have any other questions or if you need further help with getting the tweeters tuned, drop me a line at mike@exigeaudio.com
Post Number: 1642
excellent thanks exige
