Silver Member Username: Basebalz13Moneta, Va Usa Post Number: 944 Registered: Aug-07 | okay so 2 or 3 four inch aero's my vote is going to 3 4" aeros wat about yall? |
Gold Member Username: BonhamdTraverse City, MI Post Number: 1691 Registered: Nov-07 | i vote 3 |
Silver Member Username: Basebalz13Moneta, Va Usa Post Number: 945 Registered: Aug-07 | thank youuuu snow u lookin? |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6218 Registered: Nov-05 | if you can support the box volume for 3.. do 3.. most of the time peeps use aeros to save box volume ![]() |
Silver Member Username: Basebalz13Moneta, Va Usa Post Number: 947 Registered: Aug-07 | 4.25 cubes with 3 4" aero's tuned to 33 |
Platinum Member Username: Rovin1 15 = 149.5 DBs ...Trinidad & T... Post Number: 14685 Registered: Jul-05 | what size xxx ? ... |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6219 Registered: Nov-05 | I'd say a 15" according to box specs I'd drop the box to 3.75-4.00 tho.. |
Silver Member Username: CozceSt. Louis ILLside, Pronounced: ... U.S.A. Post Number: 486 Registered: Mar-08 | nvm |
Platinum Member Username: Rovin1 15 = 149.5 DBs ...Trinidad & T... Post Number: 14687 Registered: Jul-05 | oh ok if its a 15" : 4 x 4 would be some sick looooows ... |
Silver Member Username: Basebalz13Moneta, Va Usa Post Number: 948 Registered: Aug-07 | yeah 15, and 4 x 4??? |
Silver Member Username: CozceSt. Louis ILLside, Pronounced: ... U.S.A. Post Number: 487 Registered: Mar-08 | Cozce is confused |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6221 Registered: Nov-05 | 4 aeros.. |
Silver Member Username: Basebalz13Moneta, Va Usa Post Number: 950 Registered: Aug-07 | i got yall sayin 4 4" aeros would be the sexxxx |
Platinum Member Username: Rovin1 15 = 149.5 DBs ...Trinidad & T... Post Number: 14689 Registered: Jul-05 | 4x4 i meant to be 4 4 inch aeros BUT i just did some rechecking say ur box is going to be 4cuft & u obviously want loooows then 4 4" which usually comes in 17 or 18" lengths will NOT be long enough to give that true low end & the longest u can get with 3 4" will be about 35hz & im sure u want lower so u might just have to go with 2 4" or just build a sealed box ... |
Gold Member Username: Snowball123West Allis, WI Post Number: 2045 Registered: Oct-07 | would 2 be enough port area though? |
Silver Member Username: Basebalz13Moneta, Va Usa Post Number: 951 Registered: Aug-07 | ive took the PVC pipe from lows and made new tubes... the thin walled ones |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 7249 Registered: Mar-04 | Use SDR35. |
Silver Member Username: CozceSt. Louis ILLside, Pronounced: ... U.S.A. Post Number: 488 Registered: Mar-08 | Canaan, link? |
Silver Member Username: Basebalz13Moneta, Va Usa Post Number: 953 Registered: Aug-07 | http://www.dpcpipe.com/sdr35.htm |
Gold Member Username: Snowball123West Allis, WI Post Number: 2049 Registered: Oct-07 | hey kevin, you have the specs for the XXX? |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6223 Registered: Nov-05 | for the 04/05.. yes i do ![]() ![]() |
Platinum Member Username: Rovin1 15 = 149.5 DBs ...Trinidad & T... Post Number: 14691 Registered: Jul-05 | 2 4" might not be the perfect scenario but aeros tend to lessen the chances of port noise so i say try it ... |
Gold Member Username: Snowball123West Allis, WI Post Number: 2062 Registered: Oct-07 | yeah I think I'm gonna just go with 2 4" tuned to 30 HZ. And thanks a lot Kevin. |
Silver Member Username: Basebalz13Moneta, Va Usa Post Number: 960 Registered: Aug-07 | ya know he could still do like subs forward or subs up and port to the side and have the correct port lenths and sq inches |
Gold Member Username: RenegadesrunLafayette, IN US Post Number: 1050 Registered: Oct-04 | 15" XXX? One port. Snailshell. ![]() |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6226 Registered: Nov-05 | too much room.. might as well run it sealed |
Silver Member Username: Basebalz13Moneta, Va Usa Post Number: 975 Registered: Aug-07 | x2 did a lil sketchup for it lol he could loose his hole rear, btw gotta remember snow's building this ![]() |
