Quick amp question
Username: Shadowm891
Post Number: 9
i was wondering would this amp push 2 12inch kicker l5 to there full power it says its 1500 rms at 1ohm and i herd good thing about them was just not sure about there power rate Cadence z-7000
Username: Bonhamd
Traverse City, MI
Post Number: 1685
i had a cadence a7hc and it was very solid
1500 RMS will push the L5s great - it depends on the VC config to see if you can wire it to 1 ohm
if you have 2 dual 4s, the amp will work great
if you have 2 dual 2s, i would look for an amp that will put over 1000 RMS into 2 ohms
