What speakers to get with my Scott 299...
Username: Cblossom
I'm new to the whole audiophile world, and I purchased a Scott 299 tube amp and would like to get speakers that would compliment it. Any suggestions? I typically listen to classical, jazz, and rock music. Thanks!!!
Username: Nuck
Post Number: 11484
Welcome Cb. Have a look here, this will require some reading and reearch on your part to make the most of it.
http://diytube.com/phpBB2/viewtopic.php?t=1342
http://www.canuckaudiomart.com/details/112369-almarro_k303a_tube_friendly_speake rs/
http://www.coincidentspeaker.com/opinions.htm
Username: Jan_b_vigne
Dallas, TX
Post Number: 13318
https://www.ecoustics.com/electronics/forum/home-audio/546673.html
Username: Edison
Glendale, CA US
Post Number: 876
Check out the reviews done by the pros here :
http://whathifi.com/BestBuys/Hi-fi-speakers-BestBuys/Speakers/
When you are ready to buy, I would recommend getting them used here - www.audiogon.com
You will end up with more quality this way - also if you don't like them, or when you want to upgrade, you can sell them there for about the same price.
What source are you using? TRL modified Sony SCD-CE595 got great reviews - and it plays sacd which sound much better.
http://6moons.com/audioreviews/trl/595.html
Welcome to this exciting hobby Chris - just don't get the upgrade bug like many audiophiles - and buy it right from the start by doing research, and asking questions on sights like this one, or www.audiogon.com, or www.audioasylum.com
I hope you reach sonic nirvanah you are looking for...
