Need better bass in F-150 extended cab
Username: Ericsbosox
FL USA
Hello,
Frist this is what I have:
Sony Explode deck w/subdriver
AudioBahn A8002T amp
2x Memphis 15mc124d-MClass 12" SUBS
They are mounted in Ford F-150 Extended Cab Dual Subwoofer Enclosures
Underneath rear seats.
OK now my system sounds like crap!!!
for one thing the amp plays about a half an hour and quits, then there are the subs that I think the problem is the box is too shallow. The material is making a funny noise when the bass hits.
I want to drop these into my box:
2> JL Audio 12W3v3-4 - Subs
and a SONY XPLOD SERIES MODEL XM-GTR6001 1,300 WATT POWER-HOUSE MONO-BLOCK AMPLIFIER !
please I would like alot of feedback and suggestions!!!! }}
Username: Stateprop486
Phnom Penh Cambodia
Post Number: 1760
sounds like poo because you need a better HU, sony HU is trash. Your amp only plays for half an hour because your settings isn't correctly set for instance prob the gain is to high, so its overheating the amp and going into protection mode aka shutting off.
Username: Simple_smith
Lapeer, Michigan United States
^^Sony sucks d!ck. Thats a major reason it doesn't sound good. And if your box isn't big enough that will only add to the suckage.
FL USA
so you guys ay that purchasing a sony amp is not a good idea?
Username: Loudon
Post Number: 2863
sony HUs are the best thing they make actually .. and they arent that bad
Username: Blazerboy
15 $$D wangi...
Post Number: 623
Your system you have now is garbage, and what your considering isnt a whole lot better since your not fixing the main problem.
How much $ do you have in mind for spending?
Username: Jtown
Texas
Post Number: 3495
stop posting multiple threads.
