OHM
Username: El_luillo
HOW I CAN LOWER THE OHM FROM 4 TO 2 ?
Username: Imalik
15 FI BLSAZ 1500=Boom, New Jersey Jerzee Playa
Post Number: 649
Im guessing 1 dual 4 sub if so this how
Username: Nd4spd18
Philadelphia, PA
Post Number: 9557
Or, if the sub is dual 2 or single 4 then its NOT possible to get 2 ohm.
Username: El_luillo
HOW I CAN LOWER THE OHM FROM 4 TO 2 in the amp ?
Username: Imalik
15 FI BL SAZ- 1500=Boom, New Jersey Jerzee Playa
Post Number: 651
What kind of amp do you have?
Username: Glasswolf
NorthWest, MI USA
Post Number: 12372
the amp does not determine the ohm load. the circuit connected to the amp does.
in other words, the speakers, and how they are wired determine the load.
Username: El_luillo
phonics digital pd-395 1200watt
Username: Nd4spd18
Philadelphia, PA
Post Number: 9561
lol you can't
Username: Snowball123
West Allis, WI
Post Number: 2024
it says the amp is 2 ohm stable, prolly gotta bridge it since its a 2 channel.
A pic is worth 1000 posts!!
Post Number: 19711
OHM is just a measure of resistance. Resistance is determined buy the drivers and how they are wired. The less "resistance" an amp sees the more power/heat is generated and therefore more caution is needed to reduce your chance of burning your car down.
Be careful.
