Ok so my friend has a 97 mercury sable ls and he has a crunch p1100.2 and a crunch p500.2, the 1100 pushin a L5 and the 500 pushin 2 comps. The problem is when his trunk latch touched the locking latch for the trunk lid, all 3 subs go into a low frequency and go at full volume until the trunk is opened again, then everything is smooth. If just the L5 is hooked up, it works fine, if just the comps are hooked up, it works fine, but as soon as they are all hooked up it does it again. All grounds have been double checked just in case and everything is hooked up right because as long as just one amp is pushing subs they work fine. Any ideas??? Thanks guys
Well yes, admittedly a good laugh would be great right now but a pic of the install would help to diagnose the problem. It can be describe to us in words all day long and we still might not get to the root cause of the problem. But a pic could make the culprit blatantly obvious.
x2 A few pictures always helps identify the problem. I'm not just here to be a jerk, I'm also here to help
lol well i dont even know where to start. There are no grounds running to the trunk lid at all, everything is weird its insane, i think he's just gonna take the comps out to avoid problems. Ill get some pics before he takes everything out
