Need you help finding some speakers
Diamond Member
Post Number: 23182
i need to get some 6.5 inch component sets for my car. here's the catch though.....
it needs to have a small in diameter magnet and be pretty shallow mount. i want my doors back to oem looking.
thanks in advanced,
chad.
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2616
http://www.sonicelectronix.com/item_2372_Volfenhag+ZX-862R.html
Chad how much power are you running? What is your budget on this (if you even have one lol)
Username: Bernymac
Phnom PenhCambodia
Post Number: 4561
I have dibs on your dls components chad.
Username: Loc_out
Team RE XXX
Post Number: 2715
Those are going to be some clean components berny nice come up. What up Chad.
Diamond Member
Post Number: 23183
nm gus.
i am basically looking for something with decent sound. most likely i will go with a coaxial set cause i am tired of finding places to mount the tweeters.
Diamond Member
Post Number: 23184
i found one.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=7072
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2235
^^^dont look like it is that slim of a mount
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3080
if you like CDT
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6169
just get the nobeliums.. they are shallow.. or make some spacers
Diamond Member
Post Number: 23185
well the mounting depth is pretty deep now that i think about it. but the opening is a bit small. so i just need a set with narrow magnet.
there's 1 inch clearance from the top of the speaker ring to the door wall. then there's a opening to the door that is smaller than the diameter of the speaker ring. my dls has wide magnet so it don't fit through that hole so i had to put another mdf ring on top of the ring. because i did that, my door panel won't fit all the way in. that is why i am looking for another set with more narrow magnet.
Diamond Member
Post Number: 23186
oh and mark i don't like the sound of lower mid range on cdt's. its the lack of that i don't like.
kevin, like i said above, i have spacers now and because of it, my door panel don't click all the way in around the speaker.
Username: Frkkevin
Post Number: 6171
no way to modify the inside of the door panel to help the fit?
Diamond Member
Post Number: 23187
no kev. i cut everything that gets in the way. i just need speakers with narrow magnet so it can fit deeper in to the door. i just don't want to cut the opening bigger that's all.
Username: Frkkevin
Post Number: 6172
meh, chop the door up :-) ... as long as the panel covers it no one will ever know :P
Username: Glasswolf
NorthWest, MI USA
Post Number: 12346
fiberglass some door pods, or forget the door locations and go to kick pods (my preference anyway)
instead of going deeper into the doors, build the doors out to hold deeper speaker magnets
Username: Bernymac
Phnom PenhCambodia
Post Number: 4564
Chad, instead of using the money you were going to use to buy new door panels. Use that money and go get your doors done by Geary. It would look sick and you won't sacrafice your sound stage. Do it! I really want to see how Chad Geary will do your doors.
Username: Nyyfan13
Northern VA
Post Number: 10989
You aren't man enough for HAT Chad so I won't even say anything :-)
Username: Frkkevin
Post Number: 6173
or you can buy an lgt and ill sell you my pods :P
Diamond Member
Post Number: 23188
glasswolf, i think you are right and i should do the fiberglass door pods. i'll take berny's advice and get it done. as far as kick pods go, it gets in the way everytime i go to push the clutch in. well not always but sometimes and its kinda uncomfortable.
no lgt yet kev.
yanks, you are right i am not man enough for HAT so you will never see me run those. lol.
Username: Big_edge_head
Milwaukee, WI
Post Number: 3320
Haha I dunno if we'll ever see Yanks run them either
Username: Nyyfan13
Northern VA
Post Number: 10990
Lmao, just playing Chad.
And Steve, we'll see it here shortly bud. Amp is already picked out :-)
Username: Basebalz13
Moneta, Va Usa
Post Number: 871
hey Chad lee buddy, let me hook u up with some Speakaass :DDDD please
Diamond Member
Post Number: 23189
lol d-money.
yanks i know you are. i am just playing along.:-)
Username: Van_man
Boston South, MA
Post Number: 4567
USD Mids..
http://cgi.ebay.com/USD-Audio-1-pair-6-5-inch-4-ohm-Mid-Woofer-80-W-Max_W0QQitem Z200299104391QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item200299104391& _trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A131 8%7C301%3A1%7C293%3A1%7C294%3A50
Moneta, Va Usa
Post Number: 874
im serious chad! let me get you some CDT's for insanley low prices?!?!?!?!
Diamond Member
Post Number: 23190
don't like cdt.
Moneta, Va Usa
Post Number: 875
not the lower end stuff, wat bout the ES n golds?
Diamond Member
Post Number: 23191
lower end stuff? come on man i never use lower end stuff. lol. just playin man. but yeah i had the es series and i didn't like it.
Moneta, Va Usa
Post Number: 876
o00o wat didnt you like? what bout the highest end stuff?
Username: Renegadesrun
Lafayette, IN US
Post Number: 1018
One word.
Neo.
Username: Snowball123
West Allis, WI
Post Number: 1944
the matrix?
Diamond Member
Post Number: 23193
what is neo?
anyways d-money, its not that cdt sounds bad. its just the lower mid is a bit weak on those. unless i get the m series mid bass, i really don't want to go with cdt. but that means more speakers to install which i don't want.
what i basically want is a simple front stage with a simple single 10 inch sub in the trunk with a single 4channel amp powering all of them.
so soon, my dls comps, dls A6 amp, and 2 rd sq 10s will be up for sale for dirt cheap. and people that know me know what i am talking about when i say dirt cheap. lol.
West Allis, WI
Post Number: 1945
he's talking about a neo motor chad.
Username: Goodie_goop
Mid town, Texas U.S.
Post Number: 1108
dibs on 2 sq 10s
they would be sweet for my new truck
Moneta, Va Usa
Post Number: 881
you know what chad i saw these really really cool spekas at walmart they was blue and really really chromey lookin and they had neon inside them!!! so effin ballin that gets my vote
Username: Bernymac
Phnom PenhCambodia
Post Number: 4566
Chad, seriously. Stock door panels ftl. Make them bishs custom with a factory look. Nothing outrageous.
Diamond Member
Post Number: 23197
i am thinking about it berny.
D-money, not funny. sorry dude.
