Silver Member Username: IndopakPost Number: 144 Registered: May-06 | by mistake i uploaded the file without uploading the other file first. now when im trying to clean it out nothing is uploading on it. what should i do?? | |
Silver Member Username: Jwl1Post Number: 345 Registered: May-06 | Indopak--I'm not quite sure what you are saying. Do you mean you loaded the file without loading the boot file first? If so, then start over. Load the boot file first, then load the new bin after that. It's recommended that you do a factory default before starting. |
New member Username: BornagainPost Number: 2 Registered: Jul-06 | I just went thru this problem, and finally figured it out. Before you load the boot file, you must have the STB showing ON or a channel number. So first load an old PUFF bin and make sure it boots completely. Make sure to use the new 27.02 loader. Now with STB ON, load the boot file. Finally load the latest 204 bin as you normally do. Enjoy. | |
Platinum Member Username: NydasPost Number: 13936 Registered: Jun-06 | The PUFF_205 is out. https://www.ecoustics.com/electronics/forum/home-video/544654.html |
New member Username: Mlt2Post Number: 5 Registered: Jul-07 | I to am stuck on the "F" My last bin that worked was 203v2 it just froze. So I tryed to update to the 2o4 and 205 and still showing "f" The way I understood it I did not need the boot file because I was running 203 puff right? I can go back to the 203 and it's ok on booting any idea's? | |
New member Username: ProtuberentPost Number: 2 Registered: Jun-06 | I too just loaded 205 nikk bin and am stuck on F.......help! | |
Silver Member Username: JuanchoCANADA Xx Post Number: 405 Registered: Jun-08 | steve r use BLloader 27.02. now conenct your receiver as usual open loader 27.02 and choose boot 1.0.1..turn ON receiver. ( or reload bin 203 before using boot file,then do as I said) wait for F. then turn it OFF using the front button power, when led show the clock, hit download. .let it reboot, when the receiver shows channel# turn it off using back power switch, now turn it ON using same switch and when firts P appears hit download, wait for XXXXXX. do factory default, rescan and watch tv, note. lookj for nikk mty 205 bin |
Silver Member Username: JuanchoCANADA Xx Post Number: 406 Registered: Jun-08 | this is the boot 1.0.1.
New member Username: Mlt2Post Number: 6 Registered: Jul-07 | Hello, tryed all that even done the puff from start to end and still on "f". no idea what is going on. I am ok on 203 but that's it. I have a real pansat not a clone. | |
Silver Member Username: JuanchoCANADA Xx Post Number: 407 Registered: Jun-08 | then do a reset (factory default to erase all ch.) then use the BL loader 27.02 or 27.01. at last use 1.4 try all loader with 1.0.1 boot | |
Platinum Member Username: NydasPost Number: 13937 Registered: Jun-06 | PUFF_205 Stuck on "F" recovery kit If you are stuck on 'F', Use 'Stuck on_F.zip All necessary files are included Download and unzip into separate directory. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Silver Member Username: JuanchoCANADA Xx Post Number: 408 Registered: Jun-08 | some pansats 2500a doesn't load boot 1.0.1 with gtromloader 27.02, they take itwith 1.4 or 27.01 . just tested, | |
New member Username: ProtuberentPost Number: 3 Registered: Jun-06 | I am reading the instructions if stuck on F..........and i can't do: 1. Note down Antenna settings. 2. Delete all channels. 3. Do a system reset. It is stuck on F and i can't use my remote to do the above...Help |
Silver Member Username: Jwl1Post Number: 346 Registered: May-06 | Too add, if you are stuck on "F" then you will probably need reload the last file before you loaded that one, so that you can proceed to load the boot and bin file. |
