New member Username: KentutLa, Ca Usa Post Number: 1 Registered: Aug-08 | Hi there, I have Viewsat Platinum, it works well here in California. I want to try it in singapore, anyone know if there is a similar satelite like DN? |
Gold Member Username: RunnerguyPluto Post Number: 1736 Registered: Sep-06 | You don't have to hack Sat TV in Singapore. It is already free. Your box will not work though. |
New member Username: KentutLa, Ca Usa Post Number: 2 Registered: Aug-08 | Thanks for your info Zulu, I want to hack Indovision from Cakrawarta-1 satelite, 107.7°E (www.lyngsatdotcom/cw1.html) But The System Encryption is DVB Videoguard Not Nagravision. I don't think I can use my viewsat, anyone know how to do that? Or is there any satelite in Asia using Nagravision so that I can use my viewsat box? |
Bronze Member Username: KayossPost Number: 100 Registered: Feb-08 | You might want to sell it because it may not be worth anything when you get back. There will be other options in Singapore. |
Silver Member Username: Jay_w_graysonPrague, Oklahoma USA Post Number: 309 Registered: Jul-08 | Ken Tut....Like Zulu said there are some satellites that are True FTA. I have listed two 2 and I am sure you will be able to find more. Both of them are in Southeast Asia foot print that can be reach with a 75-95 cm Dish. You have nothing to lose so why not take your receiver and Dish if your Dish is between 75 to 95 cm and try it. With a FTA receiver and FTA satellite channels I can't see why it won't work. You need to add these East satellites to your receiver. http://www.lyngsat. com/nss6.html NSS 6 at 95.0°E AsiaSat 3S at 105.5°E http://www.lyngsat. com/asia3s.html Southeast Asia Foot Print ![]() |
Gold Member Username: PlymouthCanada Post Number: 6981 Registered: Jan-08 | """anyone know if there is a similar satelite like DN?""" You need a 33" dish and a linear LNB, but you will get only over 20 free channels, high price only for few channels. Grayson need to learn again. |
Bronze Member Username: L_k_live_sPOST: 100 mi... Post Number: 20 Registered: Jan-09 | m mm m h m |
