Pansat 2700a
Username: Bvvenegas
Post Number: 290
my pansat 2700a original starts freezing and then goes to scrambled or bad channel then comes back on and keeps doing this constently is that a problem with the latest bin or do i need to do something to please help
Username: Bugster999
Katy, Tx
Post Number: 148
mine 3500 and cw800 are both doing the same thing so I am guessing we have an issue probably need another bin since I have turned autoroll off as well.
Username: Bvvenegas
Post Number: 292
is there any way to fix this problem
Username: Bvvenegas
Post Number: 293
is there a old bin that does not freeze out there for pansat 2700a original
Username: Ciscomx
Post Number: 43
http://www.future-fta.info/index.php?stage=1
Username: Bladam
Post Number: 127
hi there try this bin
X-87BL_081214_B75_V202_api_femu
Username: Kewonsc
Post Number: 29
Is the x-87BL_081212_V202_api_femu A puff file or should I just be able to load and use as normal with pansat 2700A original?
Username: Nydas
Post Number: 13867
X-87BL_081214_B75_V202_api_femu is suitable for genuine Pansat 2700A. However, I suggest you try X-87BL_081214_B75_V203_apifemu
which is the one that was there before 300 and 301, and is now working reasonably well with genuine Pansat 2700A.
You can get it directly from
Username: Kewonsc
Post Number: 30
Thanks Nalin,I've been outta the game for awhile and just getting back online,haven't had a chance to get caught up with the reading.
Username: Kewonsc
Post Number: 31
Well I think I might be missing something here lol,all I'm getting is scrambled or bad channel.So my question is do I need to do the puff conversion with pansat 2700a original or just follow the rest of the steps,delete channels,factory reset,then blind scan with X-BL_081214_B75_V203 bin?
Username: Nydas
Post Number: 13877
PUFF is for 2500 converted to Pansat. You DO NOT use it for genuine 2700.
"just follow the rest of the steps,delete channels,factory reset,then blind scan with X-BL_081214_B75_V203 bin"
Username: Mozelle
Eastland, Texas USA
Post Number: 8
I am not getting all of the PPV when I do a blind scan. Should I do something different. I am using DishPro with Pansat 2700A
Username: Nydas
Post Number: 13883
The PPVs are on Echo 10/11 - 110W.
