Silver Member Username: ImauserPost Number: 114 Registered: Oct-07 | I've been watching TV with Puff V203(v2) bin on Pansat 2700clone receiver.... No freezing at all since last 20 minutes.... Enjoy and have fun |
New member Username: DomtarPost Number: 8 Registered: May-07 | Where is the PUFF file? Witch date? |
Silver Member Username: ImauserPost Number: 115 Registered: Oct-07 | 12/17/2008 Download from this website [link removed] |
Silver Member Username: JkmagoPost Number: 253 Registered: Nov-07 | Thanks buddy Working great 203V2 Cheers! |
Silver Member Username: Jaye50Post Number: 153 Registered: Aug-07 | it's freezing some...but nowhere near as bad as the others..... |
Silver Member Username: Desi_mundaPost Number: 178 Registered: Nov-07 | is it freezing or not«? |
Silver Member Username: TsconPost Number: 109 Registered: Aug-07 | confirmed: 203(v2) doesn't working on my box at all showing black screen. within start up it's showing b75 for a second If that's even matter.. |
Bronze Member Username: Post_manPost Number: 72 Registered: Nov-07 | Is there a new Bin out to replace PUFF 301 or are we looking at the end of PUFF? PUFF_V203(V-2) will not work |
Platinum Member Username: NydasPost Number: 13835 Registered: Jun-06 | Vasil Bikov: This is a PUFF thread. We are talking about instaling a PUFF_203v2 in place of PUFF_301. It seems you are not PUFF converted or you have a genuine 2700A. What receiver do you have and what were you using and what have you installed now? |
New member Username: N9terManchua, Mongolia China Post Number: 3 Registered: Nov-07 | Nalin Nyda, same thing happened to me as Vasil. I'm using 2500 converted to puff. When I installed puff 203v2 it's shown PUff then B75 for a brief second. The T.V just blank, unwatchable. I thought I download the wrong file, so I installed puff_301 back, and it work as before with freezing. I am wondering are you guys using the same version PUff 203v2 and it's working fine for pansat 2500?? |
Platinum Member Username: NydasPost Number: 13838 Registered: Jun-06 | Delete all channels. Reset. Switch off at back and on after 40 seconds. install PUFF_203v2 Do user setup Do Antenna setup Do Blind scan. |
Bronze Member Username: LavaboyPost Number: 42 Registered: Feb-06 | Converted FLU tend to always have minor freezing or related issues. Sometimes when changing channel you will get a no signal error or a "bad or scrambled channel" error message. Sometimes it will go black or freeze and you have to wait or go up a channel and back. You may freeze when scanning for channels especially if you use a switch (SW21 or Disecq) etc. Very few if any of the converted bins I ever tried worked 100% compared to my viewsat, but I have the resistor modified FLU and it still generally works and sometimes is up when the viewsat is down? But yes the 203v2 is working presently. |
Platinum Member Username: NydasPost Number: 13840 Registered: Jun-06 | "Sometimes when changing channel" I never change channels directly. If you acquire the habit of having your favourites properly classified with about 20-30 channels in each, and use your EPG to look at what you want to change to before changing channels, you will not be skimming through channels but just changing from one channel to the desired channel. |
New member Username: Pat_batemanPost Number: 1 Registered: Jan-09 | NALIN NYDA My box was converted to 2700 it was an original pansat 2500, so now is convert to 2700 using a puff something, i am getting freezing channels, one of my satelites goea away and comes back, is that normal i am suspicious about my multiswitch,( I take my pansat to a guy who installs the bins and all, what hardaware and software do I need to do it my self? I would really apreciate your help.... PB. P.S. Is DN up right now? |
Platinum Member Username: NydasPost Number: 13842 Registered: Jun-06 | See my post above at 12:24 Follow the instructions closely. You can do it yourself. You will need straight DB9 RS232 cable. You can download the files from PUFF link Download and unzip into separate directory. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Silver Member Username: TsconPost Number: 112 Registered: Aug-07 | "Delete all channels. Reset." ======================== Nalin, What you mean by "Reset". You mean "Reset to factory default?" option? Are you sure? It's not going to erase everything from the box including all "Boot/Puff" and other software from the box??? And return it to blank state "like I bought it" box? Comments? |
Platinum Member Username: NydasPost Number: 13851 Registered: Jun-06 | You do not erase the conversion. otherwise you are almost to factory state. There is some overlap in the channel lists in the memory when you change the BIN with channels already scanned. |
Bronze Member Username: KambamPost Number: 15 Registered: Apr-08 | Hi Nalin If we are not doing the reset, we can not get the picture? Because I did all the steps except the "Reset", and I was not getting the picture. The screen is blank, not even the scrambled message. Thanks. |
Bronze Member Username: Heavygirl431Post Number: 10 Registered: Aug-07 | pansat 2700a orignal worked good yesterday with 203 but is black today, and freezig with 301 |
Platinum Member Username: NydasPost Number: 13854 Registered: Jun-06 | When you switch between the full emu BINs (201-203) and the previous type of BINs (299,300,301) there are many overlapping locations in memory for channels lists and antenna setup. Hence you are required to do a clean start, which also includes switching off and ON to really clear up the memory. |
Bronze Member Username: Heavygirl431Post Number: 11 Registered: Aug-07 | nalin what do you mean when you say clean start ? |
Platinum Member Username: NydasPost Number: 13857 Registered: Jun-06 | Delete all channels, then Reset, i.e. Hit Factory Default or System Settings. Then switch off and after 40 seconds switch on. then install BIN. Then do user setup. Then do antenna setup. Then do Blind scan. then watch TV with a cup of coffee. |
Platinum Member Username: NydasPost Number: 13858 Registered: Jun-06 | See this thread. https://www.ecoustics.com/electronics/forum/home-video/543614.html |
Bronze Member Username: FarasPost Number: 14 Registered: Jan-08 | is the bin v203 (v2)the same than PUFF_V203_F_EMU ? |
Bronze Member Username: Heavygirl431Post Number: 12 Registered: Aug-07 | nalin thanks a bunch it is working fine |
Bronze Member Username: KambamPost Number: 16 Registered: Apr-08 | Thanks Nalin... it's working now. |
Platinum Member Username: NydasPost Number: 13860 Registered: Jun-06 | PUFF_V203_FEMU came out first then we had PUFF_203_FEMU_V2 to correct some mistakes. |
Bronze Member Username: ElvirmPost Number: 76 Registered: Sep-07 | Can you post puff_203_femu_v2, please? |
Platinum Member Username: NydasPost Number: 13861 Registered: Jun-06 | It is posted as alternative BINs in all of the URLs - see 1st post. https://www.ecoustics.com/electronics/forum/home-video/542968.html |
