New member Username: Method320Post Number: 1 Registered: Jan-09 | So I did a bit of research about installing a cd player, bad part is, I did the research late. I know you need a wire adapter for the factor one for it to fit. I just bought a replacement cd player for 50 bucks. I'm wondering if anyone can supply me with a picture of how the wires go into the factor wire harness.I have a hayes book, that doesnt tell me anything. So if anyone has either a 2000 sunfire, or a cavalier and can take a picture of how the wires go back into that harness, that would be amazing. |
New member Username: Method320Post Number: 2 Registered: Jan-09 | I did some research here: http://www.modifiedlife.com/2000-pontiac-sunfire-car-radio-stereo-audio-wiring-d iagram/ And it says I need to run a wire to the fuse box. But then, what do I run the wire to exactly? |
