DBPSW - 090111.x
Username: Wk66
Post Number: 28
Those who use Viewsat 2000 Ex.Does bin DBPSW-090111X work with dishnet?Are you watching right now?
Username: Plymouth
Post Number: 6949
wk66
Check your antenna setup, sometime on Viewsat the setting will change on a new bin.
Username: Joel16
Post Number: 8
I am having a hell of a time searching and locking in E7 119 channels
I think I get all E10 110 channels
viewsat plat
500 dish
2 dual lnb
diseq switch that came with viewsat
Username: Plymouth
Post Number: 6950
Joel
Try to hook your LNBs on port 3 and 4 then select those ports on receiver.
The Diseq switch furnish with Viewsat is a crap try a Digiwave or Shita.
Username: Joel16
Post Number: 9
Thanks Plymouth. But still no luck finding E7 119. I have turned off power to the 110 LNB and removed the switch. Straight from my 119 lnb to the viewsat.
Going crazy in an Ohio blizzard.
It is hard to believe that my strong signal is coming from 110. When I am not even asking it to look for 110.
Any tips?
Username: Plymouth
Post Number: 6965
Joel
Is it a new installation or the dish is already aimed?
Username: Joel16
Post Number: 10
dish was aimed. might need fine tuned. I have been adjusting it but I always come back to the same spot where I have the best signal. it just seems like 119 fell out of the sky. 110 is fine. I have loaded factory bin, Sat list and newest bin. Factory reset and search for E7. Without searching for E10 110 channels the receiver still shows it is locked on E10 110. I have 3 plats and a PVR in different locations and I have sett them all up myself. I MUST BE MISSING SOMETHING HERE. What can it be?
Username: Joel16
Post Number: 11
This is true. Viewsat plat lite. 1 dual LNB. No switch. 090111 bin. Settings for E10 110 lnb power OFF.
E7 119 lnb power on
universal
high 11250
low 9750
DISEqc none
motor off
legacy none
Scan E7 119 ONLY and get 309 Echostar 10 Channels and Zero 119 channels
How can this be?
Username: Plymouth
Post Number: 6966
Joel
Please, list your dish and LNB.
Username: Joel16
Post Number: 12
dish 500
Dual Legacy LNB Head Details:
Features:
* Suitable for Existing Analog and Digital Reception
* Various Input Frequency Range and L.O. For World Wide Market
* Circular Only
* Low Phase Noise for not only Analog also Digital Reception
* Superior Low Noise Figure & High Isolation
* Voltage-Controlled H/V Switching (13/18 V)
* Excellent D.R.O. Stability
* Super Compact Tooling
* Best Solution for Individual and Multi-Satellite System
* 40 mm Plastic Cover
Specifications:
* IF: 12.20-12.70GHz
* LO: 11.25GHz
* NF: 0.5dB
* Gain: 55dB
Username: Plymouth
Post Number: 6973
Joel
Your LNB is a DP or not?
Is it a DishPro Twin?
Username: Joel16
Post Number: 13
that is all the info i have on the LNBs.
Dual Legacy
Username: Plymouth
Post Number: 6975
Sorry
I need to know if you have only one LNB on your dish or two or a Twin LNB 100-119 in same.
Try with this strong TP 12501 (119).
From your location 110W will be very strong and 119W low signal with a dish 500.
Username: Joel16
Post Number: 15
I have 2 dual lnb like I described above.
Thanks I will try TP 12502
Have a good day and I will catch you tomorrow if I am still down.
Take Care
Username: Plymouth
Post Number: 6978
You are Welcome Joel
Username: Joel16
Post Number: 18
Still down Plymouth please check new post (help with new setup)
