I CURRENTLY IM USING A DISH 500 WITH THE SONICVIEW PREMIER. I WANT TO GET AN HD FTA BOX BUT NOT SURE ON WHICH IS BEST..WHICH SHOULD I USE? DO I NEED A DIFFERENT DISH? AND DO I NEED ANY OTHER ADDITIONAL PARTS? THANKS FOR THE HELP EVERYONE
You would need additional part to go inside your hd receiver. - unless you buy with it already installed
add another dish for 61.5 or 129 - for more hd in addition to 110w
I don't know whats the best, i would stay away from -c0olsat, captain, vs9000- c0olsat and captain dont support the add on boards and the vs9000 is discontinued
ninjad...i do not think that yor current receiver CAN be upgraded. you would need to get one that can "handle" the HD add on. There are several good ones. I have a Pansat HD9200 and it works just fine. There is also Viewsat that has a HD model.
Ok, so if I go with the nfusion nuvenio, do I need anything else? Also, do I receive ALL HD broadcasts or only on select channels? Also, where can I get one?
You will not get HD broadcasts on DN if they are Nagra 3 encoded. You will get some of he Bev HD broadcasts under Nagra 3. There is a whole list put out by sada and cartier 1 of which BEV broadcasts are available on Nfusion.
