What reset means in case of Converted FLU to Pansat (PUFF) box? Is this means just switch OFF and ON using back of the box button? Or use "Reset to factory default" option? Anyone? Thanks
Nalin, Thank you, to clear this out for me. It's working now, my only problem was "Factory Default"/ "System reset" option, I was scared that it would wipe out everything on the box including PUFF boot files . Thanks guys!
