HELP!! Missing Channels!!
Username: Maserati
hey im missing ALOT of indian channels...
like zee tv, sahara one, set usa, sony tv star india plus, star one, b4u and aaj tak
please reply fast thhxx
Username: Plymouth
Post Number: 6957
Maserati
Put the Auto Tp "off" and do a autoscan.
Username: Maserati
Thanks for reply's
BUT Plymouth when i do auto tp off, i do autoscan but the channel was not there...
im not pro on dish like you so put like this
ex: menu>>system information>>receiver upgrade etc. etc.
Username: Maserati
Thanks for reply's
im not a pro like you on dish so put like this
Username: Plymouth
Post Number: 6964
Maserati
Is it on 61.5W?
Username: Maserati
ya
Username: Jay_w_grayson
Prague, Oklahoma USA
Post Number: 304
Maserati
Delete all the channels in Echo 3 @61.5
and then do a blind scan.
Username: Plymouth
Post Number: 6967
Maserati
If you have Viewsat, delete the satellite in Channel Scan with garbage can and enter the setting in satellite menu then do a blind scan with auto Tp off exit and save return in satellite and be sure your setting is right.
Here is the good setting for 61.5W
LNB type: standard--for Dp dish put OCS-DP
LNB Freq: 11250
Tp Freq: only for see if you are on good satellite, it do nothing on a scan.
Port: choose port that you hook the LNB
Username: Maserati
Post Number: 7
nvm i solved my problems
Username: Lubfr01
Post Number: 53
I am getting alot of screens on desi channles being moved... VSU
how to get these channels on vsu ?
Username: Plymouth
Post Number: 6983
Frank
Put the Auto Tp on "off" and do a autoscan you will have duplicated channels but you will get those channels.
Good channels have "No Information"
Username: Lubfr01
Post Number: 54
I sam getting channels being moved messages on desi channels on vsu how to get these channels?
Username: Kashif
Post Number: 29
where i can find my TP , and how to turn it off i have view sat ultra, i am also having problem of mississing channels plz help
Username: Plymouth
Post Number: 6985
Frank
Check those channels are on #6--- on viewsat.
David
Menu
User setting
0000 pin code
Option2
Auto TP select off
Exit and save
Username: Jlojlo
i always gets international channels..changed from e8, 3, 7, 9...on port 3 11250 frequency..gets only international channels (61.5). How do i get cnn, hbo etc channels, Please help me!
